wheels - Page 2 - Club700XX - Honda TRX700XX Forum
 2Likes
post #11 of 18 Old 05-30-2019, 10:46 AM
Quoted: 62 Post(s)
So what tire and what size are you running in the rear?
mumbauer is offline
post #12 of 18 Old 05-30-2019, 11:27 AM Thread Starter
/CUDA's Avatar
Quoted: 27 Post(s)
Hello
21x7-10
gears also are a little shorter than 22 " tyres
/CUDA is offline
post #13 of 18 Old 05-30-2019, 12:54 PM
Quoted: 252 Post(s)
Front and rear on a 5" wheel? Wheels look great!
post #14 of 18 Old 05-31-2019, 03:36 AM Thread Starter
/CUDA's Avatar
Quoted: 27 Post(s)
Thanks !
Yes, are 4 identical wheels, 5" wide
front and rear.
At the end
were needed
Also nuts,
always conical, but 14 (metric)
/CUDA is offline
post #15 of 18 Old 05-31-2019, 08:56 AM
Quoted: 62 Post(s)
I think I like having a wider rear (tire) but let us know how it works out for you.
mumbauer is offline
post #16 of 18 Old 05-31-2019, 09:21 AM Thread Starter
/CUDA's Avatar
Quoted: 27 Post(s)
Basically,
in deep mud, or snow, it's worse,
because the wheel, narrow
put more pressure,
and then the quad goes down
while in more "normal" circumstances
the grip is good, or even very good, I can say,
like a motocross in practice,
about.
For deep mud, yes, better tires, wide.
Personally, I believe this atv,
he was not born for deep mud,
but to run a little, in off road!
/CUDA is offline
post #17 of 18 Old 08-17-2019, 02:43 PM
BadTinman!'s Avatar
Hi guys looking to see what options are out there for the rear rims and tires for my 700xx. Right now I’m running the stock rims and Kenda Cutter tires. I’m looking to maintain the 11” rim and a hard pack/ light mud tire w/6 ply tire. Looking for a quality rim just short of Beadlocks. Also I’d like to go a bit wider with out changing stock set up
BadTinman! is offline
post #18 of 18 Old 08-18-2019, 08:06 PM
Quoted: 252 Post(s)
Welcome to the club
I'm not sure why your set on the 11" rear wheel, but if you stick with that your tire options are limited to like kutters and RzR, unless you go up to a 24" tall or so tire, or maybe a 8" wide? As far as wheels go DWT red label .190 are a great option. And if you have a larger budget, you can get the OMF reinforced wheels. Personally I'd go with the 10" rear wheel, that opens up a lot more options on tires. Like the GBC Xc Masters, they are a RzR II clone for almost a 1/3 of the price. There like $43 for fronts and $65 for rears. Link to OMF reinforced wheels.
https://www.omfperformance.com/reinforced_wheels_sq.php
