-   Chassis, Suspension, Braking & Tires (https://www.club700xx.com/vb/9-chassis-suspension-braking-tires/)
-   -   Need to replace rear wheel hub axles (https://www.club700xx.com/vb/9-chassis-suspension-braking-tires/34070-need-replace-rear-wheel-hub-axles.html)
JPP 04-25-2019 11:40 PM
is there a kit (pivot works for example), to replace the small bearings of the rear wheel hub? (between wheel hub and arm). Or should you buy the original part directly and separately?
JPP 04-29-2019 05:38 AM
Nobody to inform me?
M_Quick 04-29-2019 05:48 AM
If me, I'd by the OEM bearings. But I'm sure there are many aftermarket companies selling them.
JPP 04-29-2019 11:30 PM
OK thank you. If someone has a reference for these bearings so that I compare the rate with the OEM. Here in FRANCE, I can’t find a reference for these bearings😔
M_Quick 04-30-2019 12:39 PM
Originally Posted by JPP (Post 244096)
OK thank you. If someone has a reference for these bearings so that I compare the rate with the OEM. Here in FRANCE, I canít find a reference for these bearings😔
BOSS say's world wide shipping, and free on my end, not so sure across the pond?
https://www.ebay.com/itm/Moose-Wheel...QAAOSwtpFcn51j
But I'd check pivot works, lifetime guarantee!
Pivot Works, Inc.
JPP 04-30-2019 04:03 PM
Thanks, but it’s not that bearing. It’s the little bearings between the hub and the arms.
JPP 04-30-2019 04:05 PM
The big bearing I can have it here👍
M_Quick 05-02-2019 11:42 AM
Originally Posted by JPP (Post 244104)
Thanks, but itís not that bearing. Itís the little bearings between the hub and the arms.
You'll have to be more specific, there is only one bearing in the rear hub assembly. Are you talking about the sleave, that the long bolts go through?
JPP 05-02-2019 01:49 PM
1 Attachment(s)
Parts 17-7-2 and 3-8-1-16
M_Quick 05-05-2019 04:59 PM
Yeah I'd say all that is oem only, or buy a used hub assembly off eBay.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
