DS450 with Stock Rear - what Sag & Clicker baseline - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 04-30-2019, 11:16 PM Thread Starter
Deephaven's Avatar
Quoted: 21 Post(s)
Installed a pair of DS450's. Previous owner said they were setup for around 200lbs. I am 225 in full riding gear. Hopped on the machine and had about 15% race sag. Took 5.5 turns to get it to closer to 30%. The rears are at about 25% with only a turn or so it could even go so I left them.
Made me realize since I have never ridden an atv that maybe they have different baselines than I would have expected. I figured I'd start around 30% and adjust from there. Am I off? Searching led me to nothing.
Also curious on the baseline for the compression/rebound. Classically with new shocks I would just set them in the middle and then adjust from there. That being said, if there is a better baseline or someone has recommendations I'd love to hear them.
Deephaven is offline
post #2 of 3 Old 05-01-2019, 10:11 PM Thread Starter
Deephaven's Avatar
Quoted: 21 Post(s)
I guess I am going with my baseline, would love to hear from others.
Quick teaser pic of the shocks mounted. Used a drill mounted grinding wheel and think it turned out pretty nice.
Ignore the wiring, green wire is part of my handwarmer/gps install that was only part way done in the pic.
post #3 of 3 Old 05-02-2019, 12:44 PM
Quoted: 252 Post(s)
Looks good, not sure what you mean by % of sag. Usually just adjust rear sag around 3/4".
