parking brake - Club700XX - Honda TRX700XX Forum
post #1 of 30 Old 04-27-2010, 10:43 PM Thread Starter
johnnyk1599's Avatar
parking brake
my parking brake seems to loosen up everytime i ride never really noticed till it started to roll away on a hill the other day anyone know why or is it just the calbe strechin a little bit cuz its a new bike
johnnyk1599 is offline
post #2 of 30 Old 04-27-2010, 10:51 PM
the first time i rode my xx the parking brake worked, but ever since then it hasn't..... im thinkin about just takin it off. i have no idea on how to make it work again, and it jus takes up alot of space on the handlebars...lol
boomer1 is offline
post #3 of 30 Old 04-27-2010, 11:13 PM
You have to tighten it (which is a pain in the ass to do!) It explained how to in the service manual. It is very tight in there though (insert that's what she said here) Mine loosens up every ride so I just stopped tightening it. Just put it in gear and shut it off. That's my parking brake now. Damn things are a pain
post #4 of 30 Old 04-27-2010, 11:21 PM
The reason it does that is b/c it goes off just your regular rear brake, which every time you use it is wears itself down a little bit, so over time it loosens a lot. It is a known issue on any rear disc fourwheeler, and all you need to do is tighten or, or do as crash says and leave it in gear, which is what I do. I am going to block it off tho, as i never use it, so I don't have to worry about it.
post #5 of 30 Old 04-28-2010, 12:33 AM
I think I will probably block mine off as well
post #6 of 30 Old 04-28-2010, 02:03 AM
ranger19jn's Avatar
yep that is the only complaint Ive had on this bike
Ive had mine adjusted by the dealer twice I give up asv is looking good at this point lol
just get rid of it
08 trx700xx lot's O mod's
08 ktm 525xc modded
08 yamaha 450 lightly modded
05 grizzly 660SE (sold)
11 rzr s (sold) and missed
sponsors:
Manford Auto Supply (NAPA)
Teixeira Tech:
L8aton Racing:
Fox Racing:
powermadd:
ranger19jn is offline
post #7 of 30 Old 04-28-2010, 05:21 AM
trx tas's Avatar
yeah i got rid of mine go the asv levers
trx tas is offline
post #8 of 30 Old 04-28-2010, 06:40 AM
Got rid of mine also and change perch/lever, if it's not adjusted properly; will wear out your rear brake quicker.
post #9 of 30 Old 04-28-2010, 07:33 AM
Tory trx's Avatar
Yeah its just from the normal brake usage. Its really not that bad to adjust. All it is is I think a twelve or ten mm wrench and an 8 mm wrench just brake the bigger bolt loose and hold it while tightening the 8mm bolt. Try the parking brake and if its set OK than tighten everything back up. Its only a two minute fix. I do it after every ride just to have it.
Tory trx is offline
post #10 of 30 Old 03-24-2011, 04:37 PM
Could someone post a mini tutorial with photos to explain how to adjust or fix the parking brake?
flotron is offline
