home made anti vibe solution for handlebars? - Club700XX - Honda TRX700XX Forum
post #1 of 19 Old 04-29-2010, 10:59 PM Thread Starter
markas214's Avatar
I was wondering if I put some strips of inner tube around my bars and clamped them on if it wouls help reduce some vibration. Thoughts?
Renthal 13 tooth sprocket
Alba Pro Elite nerf bars
CCP steering damper
L8ton Racing 9/16 Swaybar
Teixeira upper a-arms
Powermadd handguards
markas214 is offline
post #2 of 19 Old 04-30-2010, 02:05 AM
ranger19jn's Avatar
hmm not sure it might but it might cause it to slip as well
I am having a stem made off my bent stem for a mod quad anti vibe clamp very simple design will not cost to much to make
08 trx700xx lot's O mod's
08 ktm 525xc modded
08 yamaha 450 lightly modded
05 grizzly 660SE (sold)
11 rzr s (sold) and missed
sponsors:
Manford Auto Supply (NAPA)
Teixeira Tech:
L8aton Racing:
Fox Racing:
powermadd:
ranger19jn is offline
post #3 of 19 Old 04-30-2010, 06:42 AM
lol, Take pictures and share your results. I don't believe it will be very efficient.
post #4 of 19 Old 04-30-2010, 07:10 AM
So the other week I was stupid, and bought new weights b/c I thought I needed them as the old ones were yanked out, but then I realized I never used weights in aftermarket bars, so I just but a crap ton of wax in the bars. I believe Baxter says that he uses silicone.
post #5 of 19 Old 04-30-2010, 08:50 AM Thread Starter
markas214's Avatar
Yeah I'm sure I'd need a lot more than an eigth inch of rubber to make a difference. I do have Renthals and ODI grips. I may try weights in the ends. I've read where Harley guys wrap steel bar with inner tube ans hove them in the ends. More mass means less inertia for the vibrations. I'm going for the Precision clamps in a few weeks. My hands get numb after an hour of riding and I'm looking for a temporary solution.
CCP steering damper
post #6 of 19 Old 04-30-2010, 10:45 AM
blkcruzer's Avatar
The cheapest solution would be to pump the bars full of silicone. I did this to my protapers and it helped!!
1 tube is all you need.
2008 TRX700XX Black/Red
Mods:
Trail Tech Vapor with Riser
ODI Rogue Grips
Pro Armour FatPeg Nerfs
PRM rear grab bar
PRM .190 full skid plate
Pro Design K&N Intake
EHS Fuel programmer
22" Razr2 fronts
22" Razr rears
DS450 front reservoir shocks
L8ton 11/16 Sway bar
blkcruzer is offline
post #7 of 19 Old 04-30-2010, 11:48 AM
USMC0861's Avatar
+1 on the silicone....works well
or there is a commercial product called Bar Snake.....both work well
USMC0861 is offline
post #8 of 19 Old 04-30-2010, 11:49 AM
2006 Raptor 700
post #9 of 19 Old 04-30-2010, 01:45 PM
skier207's Avatar
I put silicone in my Poo Poo handlebar it made big difference, don't need it on the T Rex. I have been using a grip trainer also, really helps.
http://www.motionpro.com/motorcycle/.../grip+trainer/
skier207 is offline
post #10 of 19 Old 04-30-2010, 11:41 PM Thread Starter
markas214's Avatar
Originally Posted by rappyfreak View Post
My trouble is more nerve than strength related.
CCP steering damper
