A-Arms - Club700XX - Honda TRX700XX Forum
post #1 of 24 Old 05-04-2010, 11:20 PM Thread Starter
A-Arms
I have been emailing companies about a A-Arm & shock kit I was told that the 700 & 450 arms are the same is this true? has any one tried this?looking for some +1 & triple rates has anyone used some +1 or +2 would like some impressions from some one who has used them or is using them
Thanks
Scott3B is offline
post #2 of 24 Old 05-04-2010, 11:44 PM
OzLinc's Avatar
450 & 700XX are not the same......You may want to check out Houser Racing, they have a +3/4 inch arm & shock kit.
OzLinc is offline
post #3 of 24 Old 05-04-2010, 11:56 PM Thread Starter
Hey Scott,
Thanks for touching base but unfortunately, we don’t do anything for the 700 and I don’t anticipate it happening in the near future. The front end is actually identical to the TRX450 and we have sold kits to guys for that application but I don't know what they are doing with the rear.
Sorry I couldn’t be of more help.
this is the reply from Hydo dynamics this is why I am Asking, I am aware of the the houser kit just shopping around for some thing more afordable not sure if I want +1 or + 2.
Scott3B is offline
post #4 of 24 Old 05-05-2010, 12:11 AM
OzLinc's Avatar
[QUOTE=Scott3B;43368]Hey Scott,
Thanks for touching base but unfortunately, we donít do anything for the 700 and I donít anticipate it happening in the near future. The front end is actually identical to the TRX450 and we have sold kits to guys for that application but I don't know what they are doing with the rear.
[QUOTE]
I have both......it doesn't fit. You have to get a specific 700XX kit.
OzLinc is offline
post #5 of 24 Old 05-05-2010, 01:15 AM
No they are not the same... Houser has some, I have the Laeger +2 setup, Tex Tech will be coming out with some, and if all goes well, I will be working with JD Performance this summer and come up with something for the XX...
post #6 of 24 Old 05-05-2010, 08:24 PM Thread Starter
how do you like the + 2 setup & have you ever tried the houser +3/4 setup looking for the pros & cons
Scott3B is offline
post #7 of 24 Old 05-05-2010, 08:33 PM
The +2 is good for mx ,desert ,dunes and fire roads. The +3/4 is for xc and tight trails.
post #8 of 24 Old 05-06-2010, 09:21 AM
wayne matlock's Avatar
The houser +3/4 arms work great in the desert, I use them with a 4/1 DWT wheel. This setup will also work good in the woods to. On this quad wider is not better, the wider you go the more the front end will push in the turns.
Wayne Matlock
matlockracing-honda.com
wayne matlock is offline
post #9 of 24 Old 05-06-2010, 04:02 PM
What ride height do you use Wayne. I am struggling with suspension set up . I coming to think it may because of the wide rear due to using 10" rims.
post #10 of 24 Old 05-06-2010, 05:14 PM
i just ordered my houser arm and elka shocks just playing the waiting game cant wait to try them out at the dunes
