prm grab bar and aftermarket exhaust? - Club700XX - Honda TRX700XX Forum
post #1 of 14 Old 05-05-2010, 12:28 PM Thread Starter
i want to get the prm desert grab bar but dont know if it will clear my dmc exhaust. ive seen some members have cut there grab bars with the fmf exhaust. and dont want to do that. called prm and they were no help. thanks in advance.
http://prm-atv.com/MN.asp?pg=product...=1855&from=115
post #2 of 14 Old 05-05-2010, 01:07 PM
TRX_Sixpac_700xx's Avatar
Looks as if the bumper barely clears the stock exhaust. I'm guessing if your DMC sticks out further than the stock, there is a very good chance you aren't going to fit. I'd say measure to the tip of your muffler from that top bolt that the muffler mounts with, and have someone that has the bumper measure to the inside part of the bumper and you'll get your answer.
TRX700XX
-UNI Air Filter
-2Bros Exhaust
-2 Bros Juice Box
-13T Sprocket
-Pro Armor Fat Pegs (Black)
TRX_Sixpac_700xx is offline
post #3 of 14 Old 05-05-2010, 01:20 PM Thread Starter
my exhaust is 1/2 in shorter than the stock grab bar and is the same height. so if the prm is the same as stock height im prety sure it will hit
post #4 of 14 Old 05-05-2010, 01:30 PM
Had to trim mine to fit with my 2Bros, Motoworks SR4 and Supertrapp exhaust so I would say, Yes, you will need to trim it but it still works great! Just need to trim the lower handle.
post #5 of 14 Old 05-05-2010, 11:26 PM
I am going to say YES as well, as I was looking at the control bar, which incorporates the baja bar on the top. A big pain in the arse....waiting to see Nash's tomorrow to determine whether I am going to trim mine or return/sell it.
post #6 of 14 Old 05-06-2010, 12:19 AM Thread Starter
yeah i know they make good products but i can justify spending 90 dollars on something that im going to "have to make work" i think im gonna have to go talk with some people in town and make me a one off one.
heres what it looks like now
post #7 of 14 Old 05-06-2010, 12:42 AM
The desert grab bar sits higher than stock so you might be ok. Valk has the Desert Grab bar and the barker exhaust and his fits. It is close but it fits. Your exhaust looks like it sits lower than his did too
post #8 of 14 Old 05-06-2010, 01:28 AM
dmorris's Avatar
yeah i just got the prm dessert grab and it sets a couple of inches higher it should be fine
dmorris is offline
post #9 of 14 Old 05-06-2010, 09:37 PM
dagirl71's Avatar
pictures I took of it today
Da Girl
dagirl71 is offline
post #10 of 14 Old 05-07-2010, 04:14 PM Thread Starter
do you by chance have a pic. thanks
and thanks nikki thats not to bad of a trim.
5-9-10
ordered it and will she how she fits will let yall know soon
