stock shock preload - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 05-11-2010, 10:08 AM Thread Starter
Xstriker's Avatar
stock shock preload
Any advice on how to break the locknut so I can acctually adjust the suspension? As i've used a mallet and screw driver it just spins, there's gotta be a better way. Is it a 2 person job? because from reading it sounds like some people were able to do it by themselves. let me know, thx.
08 TRX 700XX
HMF Full Performance Exhaust
EHS Programmer
11/16 L8ton Swaybar
Skat~Trak Haulers 20X10X10
Alba Pro Elite Nerfs
Trail Tech Vapor Speedo/odom
Xstriker is offline
post #2 of 12 Old 05-11-2010, 10:21 AM
When you say that it spins, are u saying that both of them are spinning and if so, sounds kind of weird since I was able to adjust them with a hammer and screw driver by tapping the top spindle out then adjusting the bottom one if you know what I'm saying.
post #3 of 12 Old 05-11-2010, 11:50 AM
Tory trx's Avatar
I used a flat punch and a hammer to break them loose. But I started with the bottom one and broke it loose by spinning it down and bottoming it out. After that I just spun the top to where I wanted it( about a quarter of an inch ) and then spun the bottom up to match. I counted the threads also to make sure that they were even. Dont be afraid to hit it hard. They are not just going to spin freely at first. It also helps to lift the front end of the xx off the ground to relieve the pressure on the springs. Just make sure the P brake is on and it is secure in the air before you start banging on stuff.
Tory trx is offline
post #4 of 12 Old 05-11-2010, 12:00 PM Thread Starter
Xstriker's Avatar
yea i had mine on it's end up in the air. I'm guessing that the bottom lock nut wasn't tight against the bottom because both of them just spun albeit slowly. I was hitting it pretty hard since I was indenting the metal with a flat head screw driver. Thanks for the heads up.
08 TRX 700XX
EHS Programmer
11/16 L8ton Swaybar
Xstriker is offline
post #5 of 12 Old 05-11-2010, 03:11 PM
I mark mine prior of adjusting them up and when I rode last week, I could tell a difference with the rear ones. The front ones are Elkas so they are great!!
post #6 of 12 Old 05-12-2010, 02:10 AM
Try knocking the locking loose first (the top one) and free that up, then you should be able to just rotate the spring which will rotate the bottom nut. Simple as that, and rotate it to the point you want, and then bring the top nut down to where you want it and give it a nice slap w/ the hammer and screwdriver.
post #7 of 12 Old 05-12-2010, 06:53 AM
Tory trx's Avatar
Are we talking about the front or the rear?
Tory trx is offline
post #8 of 12 Old 05-12-2010, 09:34 AM Thread Starter
Xstriker's Avatar
front, but the rear has the same lock
08 TRX 700XX
EHS Programmer
11/16 L8ton Swaybar
Xstriker is offline
post #9 of 12 Old 05-12-2010, 09:36 AM
Tory trx's Avatar
I was just wondering because I had described the fronts and crwh45 was describing the rears. Any luck yet?
Tory trx is offline
post #10 of 12 Old 05-12-2010, 09:39 AM Thread Starter
Xstriker's Avatar
I haven't messed with it again yet, I got really frustrated with it last time I tried.
08 TRX 700XX
EHS Programmer
11/16 L8ton Swaybar
Xstriker is offline
