Rear Splines - Club700XX - Honda TRX700XX Forum
post #1 of 82 Old 05-11-2010, 10:02 PM Thread Starter
Rear Splines
Has anybody checked to see if the spline size on the rear drive shafts is the same as a Honda SRA spline? I have a bunch of R, EX, and X tires on rims sitting around and looking for a cheap way to run them on the 700. If the spline size was the same, then the SRA hubs could be shortened and the OD turned down to match the ID of the bearing seal. I am going to try it, but wanted to see if anyone had checked this out.
post #2 of 82 Old 05-11-2010, 10:05 PM
Baxter has already used 450r hubs on his XX. I believe he used the front and rear. How about you Baxter, Was it all four or just the fronts?
post #3 of 82 Old 05-12-2010, 10:22 AM
I am using front hubs , spindles and stem of a 450r . Reverting back to stock because the 450r is almost sold . Never tried the rear hubs but will see if the splines are the same. I have also had a thought about 110mm rear hubs and with a bit of research , I think I have found something.
By using 110mm rear hub you maybe able to fit 9" rim to fit 18" tyres. I cannot find any 18x10x10 mx tyres in the UK but they do make them.
post #4 of 82 Old 05-12-2010, 01:54 PM
USMC0861's Avatar
hmm....i've been looking at doing the same thing. I've actually gone to a salvage yard and pulled a bunch of hubs costing me a grand total of 10 dollars. havent really found anything that works but getting closer...i think we are on the same quest Lee.
USMC0861 is offline
post #5 of 82 Old 05-13-2010, 09:12 PM Thread Starter
Have you tried the honda small spline? Like on the 400EX, 300EX, and most everything else besides the oversized 250R splines.
post #6 of 82 Old 06-13-2010, 10:24 AM Thread Starter
I finally got around to checking on if the small honda spline hubs would fit, and it ended up being the same spline. I have a set of old aftermarket 4-110mm hubs that I am going to use. Still need to have the first 1" turned down to fit the knuckle bearing ID. I will let you know how this works out.
post #7 of 82 Old 06-13-2010, 12:04 PM
USMC0861's Avatar
good work...thanks
USMC0861 is offline
post #8 of 82 Old 06-13-2010, 02:00 PM
Sorry guys, forgot about this post.
The 700xx rear splines are the same as 450r rear splines.
If you machine the rear hub of the 450r to fit the 700xx bearing . Keeping the 450r stock overall length then stock 9" rims will fit . A spacer is needed for 8" rear rims.
I found a OEM Honda hub that might do the job as a swap with 110mm pcd. Cannot remember the model, I'll find my notes and let you know.
Would you believe I have 400 pages of notes ,Ideas and alternate oem parts that might make life easier and I've only had my 700xx for 12 months.
post #9 of 82 Old 06-13-2010, 02:13 PM
I have found my notes.
The hub needs shaving down to 34mm .
The alternate hub is off a 2009 Rancher AT TRX420FA.
Part # 42610-HP7-AO0 . At $34 each , I was going to buy a pair and try them. The only thing that might let them down is the offset.
Hope this helps as it uses the same bearing as the 700xx.
Sorry for the delay as I am trying to cure the overheating problem I have.
Should know and cure it tomorrow.
post #10 of 82 Old 06-13-2010, 08:36 PM
hey can u post some pics
