+0.75" a-arms How much difference? - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 05-13-2010, 06:57 AM Thread Starter
markas214's Avatar
3/4 of an inch doesn't seem to be that big of an improvement over stock. What is the advantage? I may do some local desert races but really just ride for fun. I can't see where I would benefit. I'm very new to quads so I'd apreciate some information. I do no about longer travel but again how much does 3/4 inch really do? I can see how better shocks will not only giive me a better ride but also allow me to ride faster so I'll be upgrading them. If I were trulty to see a big difference I'd also spring the $800 for the a-arms but would an intermediate level rider even notice the difference?
Renthal 13 tooth sprocket
Alba Pro Elite nerf bars
CCP steering damper
L8ton Racing 9/16 Swaybar
Teixeira upper a-arms
Powermadd handguards
markas214 is offline
post #2 of 7 Old 05-13-2010, 09:57 AM
wayne matlock's Avatar
They make a big difference. Not only will you get more wheel travel you will also improve the overall handling of the quad. The Houser arms allow for a better motion ratio with the stroke of the long travel shocks and also you will have more ground clearance. Another big thing is you will have full adjustment caster and camber. That will improve the steering of the quad, you can set it for a tight trail one day and the next set it up for wide open desert and it only takes about 5 min to change it.
Wayne Matlock
matlockracing-honda.com
wayne matlock is offline
post #3 of 7 Old 05-13-2010, 10:02 AM
Yep. Wider front end is better for slow-speed turning as well.
post #4 of 7 Old 04-15-2011, 02:50 PM Thread Starter
markas214's Avatar
Bumping this old thread for another question. I know Wayne also uses wheel spacers in the rear for this setup. Are they a must have, how much do they cost and where to buy?
CCP steering damper
post #5 of 7 Old 04-17-2011, 08:36 PM
AusTrx700xx's Avatar
the wheel spacers are just to bring the back out to match the front, the wider you are the better you turn, but if the front gets wider than the front then it doesnt turn so well, there not a must have but do make a difference, and i would say use them, im not sure where to get them from in the us but most online stores sell them
All readyto roost thanks to
Mike at Quadparts.com.au
Team IMS imsproducts.com
George at MonsterLab Atv
Kimberly Motorcycles
Minshull Mechanical Repairs
AusTrx700xx is offline
post #6 of 7 Old 04-17-2011, 08:53 PM
Alba for about $60-$70
post #7 of 7 Old 04-12-2012, 04:40 PM
Booser001's Avatar
Makes a good amount of difference. I fell in love all over again.
The only problem i had was the zerk fittings hit the frame gusset and pulled the threads. My fault, should of check but i was in a rush.
Booser001 is offline
