adjusting the front shokcs - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 05-16-2010, 10:03 PM Thread Starter
Alex700xx's Avatar
Whats the best preload adjustment for the front shocks. do you guys have a pics of your shocks already adjusted. and if i tighten them will it slide better on tight turns
2008 Honda TRX700xx
FMF powercore 4 slip-on removed spark arrestor-
Custom made front bumper-
UNI air filter -
Custom made seat cover-
Scott pro comp II grips-
Alex700xx is offline
post #2 of 3 Old 05-17-2010, 09:50 AM
there is a great thread in this section about adjusting, i have mine adjusted not quite halfway, and its much better, although my came from the factory adjusted completely soft.
also, wont help sliding, hard to get a IRS to slide like a SRA
Porno Joe is offline
post #3 of 3 Old 05-18-2010, 03:28 AM
markas214's Avatar
I'm 215 and mine are halfway. rears are about 1/8. I can ride wide open in 4th gear over tight whoops now. It bucks through and over them and no longer dives in. Big help. How much do you weigh? As far as getting the rear to break loose you need to power out of turns. Get the rear wheels spinning to break loose. My rears still grab a bit and I'll be tightening the preload just a little before my next ride. I had to use a small sledge and heavy screw driver to break the rings loose. Jack up the quad and you can turn them by hand once you break them loose.
Renthal 13 tooth sprocket
Alba Pro Elite nerf bars
CCP steering damper
L8ton Racing 9/16 Swaybar
Teixeira upper a-arms
Powermadd handguards
markas214 is offline
