RAZR's Won't Hold Air!! - Club700XX - Honda TRX700XX Forum
post #1 of 17 Old 05-20-2010, 10:25 PM Thread Starter
blkcruzer's Avatar
I have a left rear RAZR on the stock rim and no matter what after about 4-5 days it will go from 7 psi to about 2 psi. What do you guys use, I am about ready to slime it and forget about it!
Jason
2008 TRX700XX Black/Red
Mods:
Trail Tech Vapor with Riser
ODI Rogue Grips
Pro Armour FatPeg Nerfs
PRM rear grab bar
PRM .190 full skid plate
Pro Design K&N Intake
EHS Fuel programmer
22" Razr2 fronts
22" Razr rears
DS450 front reservoir shocks
L8ton 11/16 Sway bar
blkcruzer is offline
post #2 of 17 Old 05-20-2010, 10:30 PM
Have you soak some water/soap on the whole tire to see if you might have a small hole?
post #3 of 17 Old 05-20-2010, 10:57 PM Thread Starter
blkcruzer's Avatar
no holes, I have a large tub of soapy water for checking tires. I watched the guy mount them, He used plenty of lube on the tire and rim before airing them up to set the beads. That is why I am so frustrated that it leaks!!
Mods:
ODI Rogue Grips
PRM rear grab bar
EHS Fuel programmer
22" Razr2 fronts
22" Razr rears
post #4 of 17 Old 05-20-2010, 11:07 PM
Dumb question, but gotta ask. Did you check the valve stem? Needle tight, fully seated? Was it replaced with the tire or damaged during install?
StepNez is offline
post #5 of 17 Old 05-21-2010, 12:18 AM
hmfman91's Avatar
I ran into this problem with my Razr2s. It turned out to be the rim. I got ITP T-9 pros and the rim itself was leaking. To make a rim they have to weld 2 pieces together and it was leaking around the weld. I couldnt figure out why my tire would leak 1lb of air a day and the rim was the problem. You might want to check that out. Hope that helps.
2008 RED/BLACK 700xx
hmfman91 is offline
post #6 of 17 Old 05-21-2010, 03:00 PM
if thats it it should be a easy fix. just gota take off the tire
post #7 of 17 Old 05-22-2010, 08:51 AM
glock17tj's Avatar
I have some ITP MudLites on my 450 Foreman..The right rear leaks down from 6-7psi to almost nothing in a week or so. My Dad has a tire machine and we took the tire off and reseated it and checked all over the tired. Valve stem was fine...no holes in the tires no where. So we soaped up the tire where it meets the rim..it was leaking a little, just a few little bubbles. So we took the tire back off and Dad checked it out, come to find out the bead that it on the tire was really not there. So I guess I got the one bad tire out of the bunch. I put some rubber cement on the bead and reseated it. It held air for a few weeks but now it leaks again. I guess I just have to live with one tire that leaks down every few weeks. I air it up before each time I ride and I may loose a pound of air after riding all day or about 30 miles.. You may just have got one of those tires like I did....Live with it or just get you another tire and put that one back for a spare...
glock17tj is offline
post #8 of 17 Old 05-22-2010, 11:38 AM
Put a tube in it. It won't leak anymore.
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #9 of 17 Old 05-22-2010, 12:28 PM
Blak92's Avatar
Mine wont hold air either....
I hope the Kendas are better...
Blak92 is offline
post #10 of 17 Old 05-23-2010, 05:58 AM
I've had this problem once before. LOL
