houser arms stock break lines?? - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 05-24-2010, 11:54 AM Thread Starter
Question houser arms stock break lines??
ok question is can i run the stock break lines for awhile with the houser arms. there only 3/4 wider and there is some slack in the lines already.
post #2 of 8 Old 05-24-2010, 12:30 PM
Yes but it is recommended to use the proper ones
post #3 of 8 Old 05-24-2010, 12:33 PM
I was thinking of going this way as well when I was checking out the Elka shocks... Decided not to go with long travel a-arms, but found out that you did need to change the brake lines according to the Houser site. I don't think it's just a matter of how much wider they'll be, but how much extra travel they have... Too much for stock brake lines according to Houser.
post #4 of 8 Old 05-24-2010, 12:49 PM
Not really... I run the stocke lines with the long travel Laeger's... should I run longer ones? Definitely, I just don't have the money for them right now
post #5 of 8 Old 05-24-2010, 01:03 PM Thread Starter
everything will be here tomorrow problem is im leaving weds for the dunes and dont know if ill have time to set everything up. so if i dont have to worry about the breaklines till i get back it would be nice.
post #6 of 8 Old 05-24-2010, 01:05 PM
Good info to know. I was just replying from what I was getting from Houser.
post #7 of 8 Old 05-24-2010, 01:29 PM
yea i know what you mean... Technicaly, you should run them, but can get away with it. It's more of a liability issue, in my opinion, that any company would say that.
so to clarify, YES, run the proper lines... I just don't, lol
post #8 of 8 Old 05-24-2010, 01:34 PM Thread Starter
i guess ill just save them for last and see how it goes. might even be able to do it when i get up there. talk about cutting it close though.
