suspension settings? - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 05-25-2010, 11:59 PM Thread Starter
delinquent43's Avatar
so if you are a heavier rider as i am, 300+ is there a safe way to adjust the shocks or should i just be looking at a full revalve for closer to my weight i hear all this talk about how correctly set up suspension makes u faster so i thought i would give it a shot. and yes i do get the thing off the ground no crazy jumps but it gets air i dont know if that has anything to do with how the suspension is set up as well. any help/advice is appreciated!
2008 700xx
black/red the best color scheme!
fmf q4 slip on
prm six pack rack
13t renthal front
maxxis m9207 23x7x10 fronts
ehs lid
uni filter
ehs programmer
trail tech 1 1/8 bar clamp
new grips
pro taper contour bars
factory effex rotating clamps
delinquent43 is offline
post #2 of 3 Old 05-26-2010, 02:06 PM
The cheapest cost would be to revalve your OEM shocks, been told that our shocks are good just need a good revalve job.
post #3 of 3 Old 05-27-2010, 12:49 AM
markas214's Avatar
The rears can be revalved. I don't believe the fronts can. By the time you get them done though you could buy Stage 1 Elkas for a hundred more.
Renthal 13 tooth sprocket
Alba Pro Elite nerf bars
CCP steering damper
L8ton Racing 9/16 Swaybar
Teixeira upper a-arms
Powermadd handguards
markas214 is offline
