Rear Swaybar - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 06-03-2010, 02:31 PM Thread Starter
Rear Swaybar
My rear swaybar seems loose and is clanking back and forth..i dont see anyways to tighten it ..any tips?
tomtalbot10589 is offline
post #2 of 5 Old 06-03-2010, 02:45 PM
Do you have all the parts that attach it to the fram all tight?
Can you take a picture of where it is loose?
post #3 of 5 Old 06-03-2010, 11:22 PM
yama450yfz's Avatar
You probably just need new sway bar bushings. Check your link pins to make sure they are not worn out just give them a wiggle they should be solid if the ball clanks inside the joint they need to be replaced. Good luck
Live to Ride Ride to Live
yama450yfz is offline
post #4 of 5 Old 06-04-2010, 02:21 PM
Mine is also loose, side to side and all the nuts/bolts are tight. Guess wear and tear.
post #5 of 5 Old 06-18-2010, 01:12 AM
Kyle8ton's Avatar
If you can wait another few weeks I am going to be offering an aftermarket sway bar that helps dramatically with the understeer problem these bikes have. It comes with new bushing and mounts totally changes the way the bike rides and tracks! PM me for more details and to get on the waiting list.
Kyle8ton is offline
