ODI Grips - Club700XX - Honda TRX700XX Forum
post #1 of 18 Old 06-06-2010, 08:17 PM Thread Starter
droby1242's Avatar
ODI Grips
I want to order some Odi grips but they ask for a 120mm and 130mm grip length. does anyone know wich to order?????
droby1242 is offline
post #2 of 18 Old 06-06-2010, 08:49 PM
130 mm are fine.
2006 Raptor 700
post #3 of 18 Old 06-07-2010, 03:08 PM
im running 120mm
post #4 of 18 Old 06-08-2010, 10:10 PM
I've never used any aftermarket grips because I never had any trouble with the stock ones. Is there a huge difference in comfort?
post #5 of 18 Old 06-08-2010, 10:30 PM
Smooth, try the Odis, I swear you will never use anything else. They are much softer and a bit larger in diameter so they fit bigger hands better.
2006 Raptor 700
post #6 of 18 Old 06-08-2010, 10:40 PM
I have used an assortment of grips, and they are all different. It depends on preference, but I prefer smoother grips that are a bit softer. The stock grips for some reason always tend to grip into my hands excellent, but leave callases (which I dont mind, I grew up on a farm throwing hay and stuff, but when they are the liquid kind and pop, it sucks huge especially when getting muddy and stuff). I am using these on the xx http://www.rockymountainatvmc.com/pr...FamilyId=17906. They are pretty comfy and soft. The stock ones always have the squares in them, which is what causes my problems. It is something I can tolerate, but comfort for a few bucks to me is worth it.
post #7 of 18 Old 06-09-2010, 07:47 AM Thread Starter
droby1242's Avatar
Yeah it is a night and day difference. I ordered ODI's cause my buddy had them. I rode his for 1 minute and then decided to order them.
post #8 of 18 Old 06-11-2010, 12:42 AM
delinquent43's Avatar
i just got my odis in at 120mm, i have pro taper contour bars and the left grip wouldnt go on the bar is knurled and it didnt fit i got them on but i had to rig it... however throttle side went on easily.
2008 700xx
black/red the best color scheme!
fmf q4 slip on
prm six pack rack
13t renthal front
maxxis m9207 23x7x10 fronts
ehs lid
uni filter
ehs programmer
trail tech 1 1/8 bar clamp
new grips
factory effex rotating clamps
delinquent43 is offline
post #9 of 18 Old 06-11-2010, 12:52 AM
If the grip is still off, clean up the bar really really good, and soak the grip in hot water (try not to put it on the inside of it), that way it will expand, and then try to slide that baby one. IDK what people use, I use both grip wire and glue.
post #10 of 18 Old 06-11-2010, 02:10 AM Thread Starter
droby1242's Avatar
I got the rogues on a stock bar. I went with 130mm they worked fine. No need for glue cause they lock on.
