Breaking the bead on tires?? - Club700XX - Honda TRX700XX Forum
post #1 of 18 Old 06-08-2010, 12:33 PM Thread Starter
yama450yfz's Avatar
Can anyone tell me the best way to break the bead on my tires for dismount??
Live to Ride Ride to Live
yama450yfz is offline
post #2 of 18 Old 06-08-2010, 12:37 PM
Stand on the tire near the rim lip?
post #3 of 18 Old 06-08-2010, 01:09 PM
i had my 250lb friend do that it dint work.... u need a derimmer
post #4 of 18 Old 06-08-2010, 01:42 PM
USMC0861's Avatar
big ass c clamp, or if your not using the tires again Sawzall
USMC0861 is offline
post #5 of 18 Old 06-08-2010, 01:53 PM
Set the tire flat on the floor, get a 4-6 ft plank of wood and set it up like a ramp on the tire without touching the rim. Now get in your car and drive up the plank, this should break the bead.
2006 Raptor 700
post #6 of 18 Old 06-08-2010, 02:34 PM
TRX700XXX's Avatar
TRX700XXX is offline
post #7 of 18 Old 06-08-2010, 03:43 PM
That's strange... You don't see the cat anymore after you mount the new tire. I wonder where the cat went?
post #8 of 18 Old 06-08-2010, 04:18 PM
pay the 10 bucks to have someone else do it. its a pain in the a$$
post #9 of 18 Old 06-08-2010, 05:06 PM
Definately!!!!
I have a slide hammer, a bead breaker, and I have done the hammer and screw driver thing................they all suck!
post #10 of 18 Old 06-08-2010, 05:08 PM
b.courtney_700xx's Avatar
^^^ second that ^^^
took me and my friends 3 solid hours to break and mount 8 tires on my xx and 400ex
2008 trx700xx
dg steel series nerf bars
13t renthal
3D powertip
razrs on her feet
b.courtney_700xx is offline
