Bar Clamp for the XX - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 06-09-2010, 12:54 AM Thread Starter
Is there a 7/8" bar clamp out for the XX that relocates the lights to the inside like the over sized clamps do? I dont want to go bigger with my bars but with my Pro Taper bars I can no longer see my lights without peaking over the pad and this is not going to work anymore as I was overheating and did not notice for a bit
post #2 of 8 Old 06-09-2010, 01:11 AM Thread Starter
I'm wondering if this would work with the stock clamp just to move the lights. Any thoughts or anyone had experience with these?
http://www.trailtech.net/030-SHC01-COVER.html
post #3 of 8 Old 06-09-2010, 01:17 AM
https://www.club700xx.com/vb/showthread.php?t=2828
Try that maybe.
post #4 of 8 Old 06-09-2010, 01:18 AM
I dont know if that will work w/ the stock clamp, but you could always get bar risers if it didnt.
post #5 of 8 Old 06-09-2010, 01:49 AM Thread Starter
Do you guys think this would work if I turned it around so the lights were on my side of the bars?
http://www.motosport.com/atv/product...talogId=113311
post #6 of 8 Old 06-09-2010, 02:42 AM
I don't see why not, but your wires and everything will be exposed either way. Do you have a vent tube for the gas cap? Or are you using like a TUSK or something. I guess either way you could just shove it underneath of needed. I dont see why you wouldn't be able to swap it around, as the holes are the same either way.
post #7 of 8 Old 06-09-2010, 08:48 AM
for a super cheap fix, just zip tie the stock honda "dash" over your new bar clamp. worked for me, they are in practically the same place.
i am planning on making my own mount for the lights, just havent figured out what i wanna do yet, so the zip ties work for now
Porno Joe is offline
post #8 of 8 Old 06-09-2010, 09:45 AM Thread Starter
It's not the bar clamp that is the problem, it is the cross bar on the handle bars. But yes I have a turner vent cap so I think that modquad will work
