DS450 question - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 06-14-2010, 05:55 PM Thread Starter
DS450 question
I would really like to get the ds450 shocks but i have a couple questions. I understand that the 450x end up being about a half inch longer than the regular 450 shocks...so the question is, which one do i want or does it even matter. Also who makes the shocks for can am, and will i need to use a different spring than the one that they come with stock. Thanks for your help.
ffwood is offline
post #2 of 15 Old 06-14-2010, 05:57 PM
No idea on the 450 vs the 450x ones, the Can-am shocks are made by KYB (Kayaba).
2006 Raptor 700
post #3 of 15 Old 06-14-2010, 06:05 PM
Try this .
https://www.club700xx.com/vb/showthre...ght=DS450+swap
post #4 of 15 Old 06-15-2010, 10:31 AM
ein
ein's Avatar
Quoted: 4 Post(s)
The ds shocks are about a half inch longer correct. I just put them on with the yellow spring and adjusted the preload off as much as possible with the spring still being held in place tight. This has worked great!! huge inprovement over stock and a little bit of extra ground clearance too... didn't take measurements before i put them on but now the botton of the frame between the front of the two controll arms is 14 1/2 inches. Someone take a measurement of stock.
Removed reverse rev limiter
Ds450 shock swap
EHS fuel programmer
Big Gun EVO R slip on
ein is offline
post #5 of 15 Old 06-15-2010, 12:43 PM
FFWood, it doesn't matter. From everything I can tell, the difference between the two is color. I asked the guy I bought mine from as he races in GNCC, and that is what he said. Mine were half an inch longer than stock, and I have the regular 450 shocks, DaGirl's got the X shocks and hers are the same length. Just do what EIN said about the preload, and you will be good. Of course you can tighten them down even more as well though like TRIZZ, but I think that makes it sit up way to high, plus not as much bounce.
post #6 of 15 Old 06-15-2010, 03:57 PM
I did the same thing that "ein" did. I have the X model shocks installed, and love them. I adjusted the preload all the way off, while keeping the spring tight. If you do that you should not have any problems
2008 700xx Barker Full, EHS Lid, EHS box, Uni Filter, 13T sprocket, DS450 shock swap, Pro Taper Contour Bars, Spider Grips, Front: ITP Baja's & Razr 2's, Rear: ITP9's & Razr 2's
jwherndo is offline
post #7 of 15 Old 06-16-2010, 10:15 AM Thread Starter
Thanks for everyones help...it all makes since now. Ein, i am currently at work but i will let you know how high mine sits tomorrow afternoon when i get home.
ffwood is offline
post #8 of 15 Old 09-12-2010, 10:08 PM
13 inches
D.Shobe is offline
post #9 of 15 Old 09-13-2010, 04:43 PM
Originally Posted by D.Shobe View Post
13 inches
Wish I could say that. More like 5 1/2" here.
Tom
08 Outlander 800
08 Yamaha Big Bear 400 4x4
OHV Wildcat is offline
post #10 of 15 Old 09-13-2010, 04:51 PM
How is yours 5.5", measure end to end.
