The cheap way to fix it... - Club700XX - Honda TRX700XX Forum
post #1 of 36 Old 06-18-2010, 01:33 AM Thread Starter
xxTheDarkLumpxx's Avatar
When I road the 700xx the first time and a came into a turn at speed I remember thinking...Whoa, ...WTF. I had read about the issues with pushing and body roll, but there is nothing more magical than experiencing it yourself. I've ridden SRA's my whole life. This was new, and it wasn't good. Now, I have a friend with a Renegade, and he let me ride it a couple of times. I did notice the difference with IRS in turns, and the tendency to come up on two wheels, but it wasn't scary, and I felt that I needed to be careful, but things were under control. The 700xx actually scared me a bit, like I might wreck if I went as fast as I was used to going.
Otherwise the machine delivered wonderfully, amazingly, making me feel like I could take on anything, (especially that Renegade..lol)...if only there were a simply way to fix it. ...so I google'd till 2:00am.
The sway bar is too small and weak. Everything comes down to that. Argue all you want, everything I read about excessive pushing and body roll in the high performance world, be it cars, trucks, or four wheelers, the answer is always the same. Aside from an obvious issue with weak shocks, always go with a bigger and/or stiffer sway bar...sweet, sublime handling follows immediately. (with maybe a little rougher ride) So...
Options:
1) Live with it.
2) Put Band-Aids on it...tires, shock mods...help it some...
3) Spend $500 bucks on an over-engineered aftermarket sway bar.
4) Come up with my own solution.
I really wanted to do either 2 or 3, but financial realities demanded otherwise. So, as they say, "Necessity is the mother of invention." Good 'ol option number 4.
The sway bar is really a torsion bar. The 90 degree arm that connects to the swing arm is really just a moment arm (lever) that twists the torsion bar about its center axis. If you dig into the physics of this relationship, it all comes down to torque, distance, and torsion resistance. The key relationship that I realized could be exploited in our particular scenario is that the distance away from the center axis of rotation determines the force necessary to deflect or twist the bar. There is a direct relationship that says the force needed to deflect the bar is inversely proportional to the distance from the center axis of rotation. In other words, move the connection point closer, make the lever smaller and the swing arm would have to work its ass off compared to the stock position. In even more other words, it is saying that body roll would be cut in half. That is significant for sure. It was so simple it was scary. I didn't need a bigger thicker sway bar, I only need to connect with it closer to the axis. In fact, if I changed the connection point to the mid point between the existing connection and the axis, I would double the force needed to deflect it the same distance. Easy, cheesy, Japanese-ee (no offense Honda).
I wanted it to be very simple and easy, leaving the machine as stock as possible and using as many stock parts as possible. You can see in the pictures that I used three basic pieces of bar stock of steel and aluminum, and five bolts with nuts. Some drilling and tapping and I was in business. I painted the "non-stock" parts yellow, so it is easy to see what has been added to the machine...not much.
So, how does it work...? I would say that it is not the same as a SRA, but definitely as good as the Renegade. There is a hint of pushing, but below the surface now. I ride with confidence. That weird feeling is gone. I have to do much less body position work to corner, really about the same as with SRA, maybe just a little more. It really is a different machine. I am convinced now that a thicker sway bar (which achieves the same thing as moving the connection point) is the answer. Honda are idiots for not offering a "performance" sway bar for $100. They would get their credibility back on the 700xx and wouldn't have to give it away for half price. Not sure who has their head on backwards, but it is a real shame.
I'm on stock tires and shocks. The rear adjustment is backed all the way off as was original. The fronts I adjusted half way and liked it much better (well before the sway bar mod). I have only about two hours ride time on it, but since the sway bar is still essentially following the stock deflection path, there are no issues with interference. Everything moves free and clean. I tested it for one hour with my wife on back riding double. Together we are 330lbs. (Notice I avoided time in the dog house by not mentioning her weight) I ride north Georgia mountains which are steep, rutty, and twisty. I worked the hell out of the suspension and no issues. Everything stayed tight and solid. I'm very happy with it. I was also surprised how well it handled the extra weight of a passenger. My mod wasn't doing that. Makes me think Honda was overcompensating with heavy shocks to offset the body roll. While at the same time using a tiny weak sway bar...they strayed off the path...I think I have found the way back on it.
xxTheDarkLumpxx is offline
post #2 of 36 Old 06-18-2010, 07:18 AM
Nice!
post #3 of 36 Old 06-18-2010, 10:07 AM
ein
ein's Avatar
Quoted: 4 Post(s)
Very interesting! My next mod was going to be a sway bar, but i may just try this out.
Removed reverse rev limiter
Ds450 shock swap
EHS fuel programmer
Big Gun EVO R slip on
ein is offline
post #4 of 36 Old 06-18-2010, 01:02 PM
scrawny's Avatar
although this all sounds good and you hit the nail right on the head as far as how to stiffen the sway bar i see some issues with this theory.
the reason this quad pushes in corners is because during cornering the inside wheel stays planted/doesnt get lighter as an SRA quad does. on an SRA quad the body roll actually lifts the inside wheel causing it to loose traction causing a loose/oversteer condition.
limiting body roll on the XX would keep the inside wheel planted even more making it push worse. i personally think the way the XX handling inspires confidence during high speed cornering because i never get the loose "loop out" feeling i do on SRA quads. you have to ride the XX more like a threewheeler staying as far forward in the saddle as possible, throwing the back end of the machine with your feet, then staying in the gas hard to keep it sliding.
again, you are thinking right on stiffening the swaybar, but i dont think you are ever going to make the XX handle anything like an SRA quad because they were designed with two totally different schools of thought...
08 700xx
05 Ruckus
04 450r
86 Fat Cat
86 350x
81 250r
72 CB100
scrawny is offline
post #5 of 36 Old 06-18-2010, 01:21 PM
ranger19jn's Avatar
that sounds viable but your missing one very important part the reason the bike dont slide is not just the rear its also the front
the inside front lifts loosing all traction which allows the two planted rear tires to over power the one front tire and it goes where your poited
stiffen the sway bar and keep all four tires planted for the most part makes it more predictable in the corners
as far as making it handle like a SRA if thats what your after go buy one
I just want it to be more predictable
08 trx700xx lot's O mod's
08 ktm 525xc modded
08 yamaha 450 lightly modded
05 grizzly 660SE (sold)
11 rzr s (sold) and missed
sponsors:
Manford Auto Supply (NAPA)
Teixeira Tech:
L8aton Racing:
Fox Racing:
powermadd:
ranger19jn is offline
post #6 of 36 Old 06-18-2010, 03:49 PM
redrider's Avatar
Nice posts guys, this is my biggest complaint about the xx. I agree, the sway bar is too weak, super idea in modding the stock bar, thanks for the write up.
redrider is offline
post #7 of 36 Old 06-18-2010, 04:23 PM
I am glad TDL is trying something differant. This is how the 700xx will get better.
post #8 of 36 Old 06-18-2010, 07:48 PM Thread Starter
Hmmm...I guess if you look at a IRS and an SRA, the main difference is that the SRA is more rigid. When you come into a corner, the rear wheels (and thus the rear part of the quad) stay pretty much parallel to the ground. The axle is really resisting the body roll and instead of gripping, the tires break traction and you slide. The IRS is less rigid and allows the body to roll and in turn the whole quad losses parallelity with the ground. It promotes the outside rear to really bite and the quad doesn't slide. That I think is the key.
In terms of being able to ride as fast as possible, it makes sense that you want to have as much traction as possible. Any time the wheel is sliding or spinning the power is not moving you forward as much as it would if it were gripping. The bad side is that cornering with excessive body roll gets the inside wheels off the ground and tends to want to pitch you over sideways. If you're dealing with a situation where the faster you corner the more it wants to tip, obviously this becomes the limiting factor. This is seen when riding on pavement with an SRA when, for that set-up, you are seeing what it is like to have good traction and less tendency to slide. Things get tippy. I think there is something to be said about too much traction.
The problem with the stock setup is that it is allowing too much roll. It makes it pretty hard to control. I think it is a compromise. On the range scale, at one end is the SRA and a "beat you too death ride" over bumps, but with very easy to control (and fun) cornering ability. At the other end of the scale I guess would be a IRS with no sway bar at all and "never slip" traction, super smooth ride over bumps, but a terrible tendency to roll over and kill you in every corner. Would be like trying to ride a giant marshmallow. If this weren't the case, we'd all be taking our sway bars completely off and riding that way.
So, how much is too much, or how little is too little. You have to pick a spot in between where you have the benefits of IRS, but still manage to have predictable cornering ability. This is controlled mostly by how stiff the sway bar is. What I believe happened with the 700xx is that they missed the mark and ended up with a quad that makes people go..."Whoa, that ain't right." So what I did was slide my machines tendency a bit away from the "bite and roll" side of the fence to the "stand-up and slide" side of the fence. I don't want to give up too much of the IRS benefits, just want to have better control in the corners. I think most people feel this way, as so many are buying special tires and other mods to help move the performance in that direction. Out of the box, the 700xx needs to be fixed.
I know I'm on to something as the performance of the machine now is definitely showing this effect, as the cornering is much easier and more fun. And I'm doing it on stock tires. So far I haven't noticed any significant loss in the IRS benefits over bumps. I haven't rode it a lot since doing it, so time will tell if I changed it too much.
The interesting thing is that I believe I can make this set-up adjustable. Play around with it till I get the best of both worlds. I am most happy about the fact that the "ability" to get where I wanted to go is within the stock bar. The sweet spot is within the range of adjustment the stock bar offers. I didn't have to figure out how the heck to get around that.
post #9 of 36 Old 06-18-2010, 08:44 PM
Craigy72's Avatar
I think I'll just work on mastering the corners the way it is built and see what the difference is between it and my other 4 wheeler that has SRA. I'm just starting to get the rear end to float a little bit, but it is not easy. I can pretty much drive sideways with the SRA.
2008 Black/Silver Honda TRX700XX
2005 Polaris Phoenix 200cc pooper-Sold!
Wherever you go, there you are!
Craigy72 is offline
post #10 of 36 Old 06-18-2010, 09:12 PM
scrawny's Avatar
i guess i just ride super agressively. ive never had a problem with it 2 wheeling any worse than my 450r did in stock form. you DO however have to ride them completely different. both quads are tippy on pavement, but any atv (a vehicle that was not designed to operate on pavement) is.
im from the school of thought that there is never too much traction. ive NEVER felt more confident in high speed (high 4th-5th gear corners) than with this machine. it is one of the most balanced (tration-wise, front/rear) quad ive have ever ridden. i also would not want a quad that has as much power as this one does not have enough side bite. think of how bad it would be if honda hadnt outfitted it with the relatively small/short sidewall/small contact patch rear tires?
^^ this rider is at full throttle coming out of a corner and is on 2 wheels its just a matter of comfort. the inside tire is lifting, leaving ONLY the right rear wheel to drive it out of the corner under acceleration causing it to want to pass the left rear wheel making it yaw out.
your idea is a good idea if thats what you are looking for. you cant really bag that hard on honda because some of us havent had the same issues you have had with the handling of the quad. if you wanted it to slide more you could always just make a lowering kit which would effectively "stiffen" your swaybar as well. again just different approaches that would end the same.
08 700xx
05 Ruckus
04 450r
86 Fat Cat
86 350x
81 250r
72 CB100
scrawny is offline
