Rear Rim for 700xx and 450r - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 06-22-2010, 03:10 AM Thread Starter
Is there a 10'' rim that will suit the 700xx and the 450r. Are the bolt patterns the same on the rears of each? Thanks
froggy is offline
post #2 of 11 Old 06-22-2010, 03:39 AM
OzLinc's Avatar
YES.......
NO......
Unfortuneatly its the front 450R wheel that will go on the rear of the XX and that doesn't really help.
OzLinc is offline
post #3 of 11 Old 06-22-2010, 04:32 AM Thread Starter
ok cool would it possibly work with an adaptor if there is such a thing?
froggy is offline
post #4 of 11 Old 06-22-2010, 08:08 AM
OzLinc's Avatar
There are all sorts of options for wheels and widths.......what are you trying to acheive?
OzLinc is offline
post #5 of 11 Old 06-22-2010, 06:24 PM Thread Starter
a rim that i can use some existing tires from my 450r on my 700xx but could also use the rim on the 450r if i didnt want to swap tires at the time.
froggy is offline
post #6 of 11 Old 06-22-2010, 08:49 PM
OzLinc's Avatar
The only thing that will fit is the fronts from the 450R. They will fit on the front or rear of the XX.
The rear of the XX is a PITA when it comes to wheel and tire combos..........
OzLinc is offline
post #7 of 11 Old 06-22-2010, 09:08 PM Thread Starter
Ok fair enough, do you believe for something like Finke Desert Race that running fronts on the rear is an advantage?
froggy is offline
post #8 of 11 Old 06-22-2010, 10:15 PM
OzLinc's Avatar
NO.......!.........the best tires for Finke would be the new KENDAS. Some people use the narrow tyres for desert as they say they are more stable at speed. That may (or may not) be true for them but the XX is heavier than most sports quads so it needs a bigger foot print. Also at Finke the bull dust can get so thick and deep that you will need the widest tyres possible to try and sit on top of it rather than cut through it to try and find hard ground.
I hope that helps......
OzLinc is offline
post #9 of 11 Old 06-22-2010, 11:02 PM Thread Starter
Yeah it does hopefully will be able to do it next year. I already have a 11'' razr's for the rear (won them) and rzr2's for the front and have a set of OMF beadlocks same as Smithy's i think. Are you doing safari this year?
froggy is offline
post #10 of 11 Old 06-23-2010, 12:33 AM
OzLinc's Avatar
You won some RAZR's.................use them for the year and do the race on the Kendas. Smitty tore up the MAXXIS and punchured them on Day 1. the KENDAS weren't available.
Not doin Safari this year as I dont have the funds or the quad. My XX isn't anyware near ready. I will be helping Smitty and PeteW get there XX ready though, lots to do with custom alloy tanks and navigation tower.
OzLinc is offline
