i guess this is where it goes? - Club700XX - Honda TRX700XX Forum
post #1 of 19 Old 06-23-2010, 10:01 PM Thread Starter
scrawny's Avatar
i went riding today just to get some practice laps getting ready for a 4hr enduro. everything was going good, the motor feels like its loosening up more and more.
...now for the bad...my seat kept coming loose. granted it was a rough track, but not that rough. i couldnt tell if it was coming loose when i was sitting down or when i was standing up. i only noticed it when standing up. after the 2nd time it happened i made sure the latch was all the way in the foward position. then it happened two times after that not really the most confidence inspiring feeling. needless to say i will have to rig it so it doesnt happen when im racing sunday.
anyone else have this happen? the quad has never been wrecked and is only on its 4th or so tank of fuel. i will call the dealership to see if there is anything they can do about it, or if they have a service bulletin out on it...
08 700xx
05 Ruckus
04 450r
86 Fat Cat
86 350x
81 250r
72 CB100
scrawny is offline
post #2 of 19 Old 06-23-2010, 10:07 PM
USMC0861's Avatar
Never..mine Goes On Tight As .....
USMC0861 is offline
post #3 of 19 Old 06-23-2010, 10:43 PM
OzLinc's Avatar
I've never heard of this on a Honda let alone a XX.
If both latches are on properly then the seat is flexing in the middle. If it's flexxing in the middle then its not seated on the side plastics and over the frame rails somewhere. Are the plastics on straight?.......
OzLinc is offline
post #4 of 19 Old 06-23-2010, 10:50 PM
Yes I happens on the xx... not personally to me, but wayne, josh, and jeff have a hood pin... like one from autozone... and ficed it that way but you have to remove your tailight... I guess I just got lucky, but it happens when riding gets rough
post #5 of 19 Old 06-24-2010, 08:24 AM Thread Starter
scrawny's Avatar
i know...usually this only happens to suzukis and other lower quality brands.
all plastics are straight. as i said its only on its 4th tank of gas. it is flexing in the middle enough to leave marks from the bottom of the seat on the airbox lid.
guess i will have to do the hood pin trick but will want to keep the tail light on. gonna have to figure out another way.
08 700xx
05 Ruckus
04 450r
86 Fat Cat
86 350x
81 250r
72 CB100
scrawny is offline
post #6 of 19 Old 06-24-2010, 07:17 PM
OzLinc's Avatar
Thats a worry......I've always thought that the seat sits too close to the air box to use one of those EHS air box lids. This just confirms my thoughts.
OzLinc is offline
post #7 of 19 Old 06-24-2010, 08:07 PM
Superswire's Avatar
man, zip-tie that sucker and ride it, lol...
honestly though, i wiegh 220lbs and hammer my seat jumping and wheelying, i stand on it, use it for a ladder, ride passengers, slide backward and forward, hang way out over my front tires with my one knee digging into it and my other hanging on the other side of it, even mount it like a horse sometimes running full speed and land sitting down and it never came loose yet. i did however put it on wrong once and lost one of the damn rubber donuts that go on the frame. Hope you find the problem or at least a decent bandaid !!!
Superswire is offline
post #8 of 19 Old 06-24-2010, 08:59 PM
What set up are you using ?
post #9 of 19 Old 06-24-2010, 09:11 PM Thread Starter
scrawny's Avatar
right on man i ride EXTREMELY hard too.
i did notice that one of the rubbers was missing. i just figured it came out after the seat was coming loose.
i did tap the latching "u" on the rear of the subframe back towards the rear of the machine to get it closer to the stock latch. i will replace the rubber and do some cobbing to the rear plastic nipples that go through the rubber grommets on the rear of the seat for the race. im not going to give it a chance to come loose at the race but i am running out of time to test it before the weekend.
i will ride it without the cobbing after the race to see if tapping the "u" foward and a new (off one of my trikes as they are the same) forward rubber piece will be suffice.
08 700xx
05 Ruckus
04 450r
86 Fat Cat
86 350x
81 250r
72 CB100
scrawny is offline
post #10 of 19 Old 06-24-2010, 09:33 PM
Superswire's Avatar
estatic
Good luck to you with your seat as well as the race man !!!
At least i know who to ask when mine breaks
