Razr II and ITP wheels - Club700XX - Honda TRX700XX Forum
post #1 of 14 Old 06-24-2010, 09:04 AM Thread Starter
Wheels and tires just came in from RM and they look great. With that said they are just way too heavy. ITP wheels and 22x11x10 Razr II's weigh 22lbs each. The stock wheels and tires are 18lbs. Tires look great and I am sure will hook very well but at 8 lbs extra rotational mass on the rears its just too heavy. :(
nm700xx is offline
post #2 of 14 Old 06-24-2010, 10:39 AM Thread Starter
Some pics
nm700xx is offline
post #3 of 14 Old 06-24-2010, 11:40 AM
traitor08's Avatar
I would almost bet your faster with the razrs than the factorys. Spinning slows you down, I would rather it be heavier and get traction than be lighter and spin alot. But if it's that big a deal, do burnouts till they weigh the same. That being said, I want the exact combo you have. Those tires look great for trails.
traitor08 is offline
post #4 of 14 Old 06-24-2010, 03:07 PM
ein
ein's Avatar
Quoted: 4 Post(s)
Wow! Your rig looks sexy! I just can't imagine how some folks actually think black is faster than red!
Removed reverse rev limiter
Ds450 shock swap
EHS fuel programmer
Big Gun EVO R slip on
ein is offline
post #5 of 14 Old 06-24-2010, 05:08 PM
1: stock wheels are cheep 2pl tires razar 2 are strong 6pl
2: 8lb is not that much not even a gallon of gas
3: u will hadle alot better
4: why do u care so much about only 8lb
post #6 of 14 Old 06-24-2010, 07:01 PM
It is just not the weight of the item, it is that it adds “Rotating weight”. The heavier tire you have, the more the engine has to work to spin them. I run both razr’s and razr2’s on my 450R’s, the difference in engine performance is very noticeable between the two. The engine revs out faster with the lighter razr’s on the quad, one of the main reasons I prefer the razr over the razr2.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #7 of 14 Old 06-24-2010, 10:11 PM
So why not get the razor? Just curious why u got the heavier when u already preferred the lighter tire??
Captamer71 is offline
post #8 of 14 Old 06-25-2010, 10:32 AM Thread Starter
That is well put. On rotaional weight it is more then the weight you add. When you look at cars etc I have seen it said 1lb of rotaional mass can be like adding 5lbs of weight to the car. So even if we say it is 2lbs for every 1lb of RW that would mean with 8lbs of RW the atv would gain 16lbs. on a 500lb 50hp atv that is huge. It may not be as bad on a straight trail with a set speed but for hill climbs, dunes, drag racing etc it will put me at a big disadvantage. Did some digging to razr in 22x10x11 is 14.5lbs, razr in 20x11x10 is 14.33lbs and razr 2 in 22x11x10 is 19.3lbs all of these weights are with out the rim. So you can see an almost 5lb increase going to razr 2's.
Doug
nm700xx is offline
post #9 of 14 Old 06-25-2010, 04:08 PM
blk84's Avatar
Some pics
Razr's II simply look mean. Too bad they don't fit stock rims and that they're heavy.
08 700xx aka hillclimber
"If you want something done right, do it yourself"
Dominated...
SW, PA
Wellsville, OH
Buffalo Mtn, WV
Little Coal River, WV
Bearwallow, WV (every blk/red trail)
Rockhouse, WV (every blk/red trail)
Indian Ridge, WV
Pinnacle Creek, WV
blk84 is offline
post #10 of 14 Old 08-03-2010, 10:52 AM
Spr3ck3ls's Avatar
what are you rim dementions i would like to get rims like your rear rims but in black but i dont know what dementions will fit on my quad.
Atv Goals
1. Barker Exhaust
2. Dyno Jet Power Commander
3. Uni Air Filter
4. Works Performance Shocks
5. Race hard and fix along the way
Spr3ck3ls is offline
