Front fenders removed - Club700XX - Honda TRX700XX Forum
post #1 of 38 Old 06-29-2010, 07:07 PM Thread Starter
Can people who have removed the front fenders post some pics. Also does the headlight and grill still bolt back on with the front outer fender removed? Thanks
froggy is offline
post #2 of 38 Old 06-29-2010, 07:21 PM
Superswire's Avatar
I had to put 2 zip ties on the bottom of my grill and the 2 fender mounts stick out near your knees, not enough to get in the way or anything, but they look dumb, so i put mine back on for now, there are also some small tabs that connect the hood to the fender, you can shave them with a razor blade held on a 45 degree angle and pulled very slowly towards you, then using some sandpaper, just smooth em out where you cut if theyre jagged, i really liked the look of mine, here's the only pic i have of them off, you can probably see the 2 neon green zip-ties holding the grill on towards the mottom of it...
Superswire is offline
post #3 of 38 Old 06-29-2010, 07:25 PM
I did the same thing except I put a rubber hose between the grill and the frame:
post #4 of 38 Old 06-29-2010, 07:26 PM
TRX700XXX's Avatar
Did the same with tie tie's and removed the paper part so its just the inside metal part of the tie tie's.
TRX700XXX is offline
post #5 of 38 Old 06-29-2010, 07:29 PM
Guys,
I would remove your brackets, you're seriously going to mess up your knees.
I came so close to doing irreparable damage it's not funny.
post #6 of 38 Old 06-29-2010, 07:32 PM
There is a post on this and I seem to remember Phucknutz had found a way to bolt the hood down.
post #7 of 38 Old 06-29-2010, 07:37 PM
TRX700XXX's Avatar
Guys,
My knees never came close to the brackets. I'm 5'8" and never had a problem with it.
post #8 of 38 Old 06-29-2010, 07:39 PM
Superswire's Avatar
haha, looks good, yours match better than mine scuzz, its all i had though, lol...its way beter for wheelies, you can actually see !!!
post #9 of 38 Old 06-29-2010, 07:40 PM
I was going to take them off before the Hatfield trip, but I'm soooooo glad I didn't.
post #10 of 38 Old 06-29-2010, 07:42 PM
Superswire's Avatar
Scuzz are your brackets off ? How did you secure your hood if they are ?
