shocks - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 06-30-2010, 02:56 PM Thread Starter
shocks
right i have my ds450 shocks ready to fit. need to trim the upper mounts on the quad but cant find the photos that are on this forum showing where to cut.
any one know where they are
mods to my trx700xx
corsasri is offline
post #2 of 5 Old 06-30-2010, 03:10 PM
ein
ein's Avatar
Quoted: 4 Post(s)
I just started triming untill they fit.
Removed reverse rev limiter
Ds450 shock swap
EHS fuel programmer
Big Gun EVO R slip on
ein is offline
post #3 of 5 Old 06-30-2010, 03:16 PM
blkcruzer's Avatar
https://www.club700xx.com/vb/showthre...t=ds450&page=4
2008 TRX700XX Black/Red
Mods:
Trail Tech Vapor with Riser
ODI Rogue Grips
Pro Armour FatPeg Nerfs
PRM rear grab bar
PRM .190 full skid plate
Pro Design K&N Intake
EHS Fuel programmer
22" Razr2 fronts
22" Razr rears
DS450 front reservoir shocks
L8ton 11/16 Sway bar
blkcruzer is offline
post #4 of 5 Old 06-30-2010, 05:48 PM
I would take a side grinder, and just start trimming on the mount. By using the grinder, you can keep a radius and you cant tell that you have even done anything. That is if you use a little touch up paint.
Take off a little bit at a time and see if the shock fits. Keep doing that little by little till it fits
2008 700xx Barker Full, EHS Lid, EHS box, Uni Filter, 13T sprocket, DS450 shock swap, Pro Taper Contour Bars, Spider Grips, Front: ITP Baja's & Razr 2's, Rear: ITP9's & Razr 2's
jwherndo is offline
post #5 of 5 Old 06-30-2010, 07:35 PM
but mod the shocks do not mod the frame as it will make it weaker and frames aint cheap to fix.
