brake fade? - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 06-30-2010, 08:35 PM Thread Starter
scrawny's Avatar
brake fade?
just wondering if any of you have had any brake fade? my front brakes get pretty mushy after about 30mins of hard riding.
i was thinking of trying the adjustable stock trx450r lever. you could increase the throw giving you more room before it bottoms out on your other fingers. knowing honda it has to work right?
08 700xx
05 Ruckus
04 450r
86 Fat Cat
86 350x
81 250r
72 CB100
scrawny is offline
post #2 of 15 Old 06-30-2010, 08:43 PM
Superswire's Avatar
Honestly, my brakes work pretty good, have you checked your pads lately ? Scuzz said his pads were destroyed and wasnt squeaking or anything...
Also, stainless lines and racing compisition pads will prob help more than a lever IMO
Superswire is offline
post #3 of 15 Old 06-30-2010, 08:44 PM
Pinto's Avatar
if the brakes are getting really spongy it could be due to a worn master cylinder.
Pinto is offline
post #4 of 15 Old 06-30-2010, 09:08 PM
Superswire's Avatar
noway man, you are probably boiling your brake fluid, i know alot about this because i drive like a retard...
if the master was bad it would stay spongy even when cold, if its only spongy when its hot, you are boiling your fluid i'll bet anything and when you boil fluid gases escape and the feeling of sponginess is the same like if you had air in your lines, get some cooler running race pads and performance brake fluid like dot 5.1 or something...
if it still acts up when its hot and you have performance pads and racing fluid in there, and no contaminants, i will sell my xx for rock bottom and never post on this forum again...
post #5 of 15 Old 06-30-2010, 09:14 PM
Superswire's Avatar
anything you can do to make your brakes cooler will help, they actually make titanium shields that go between your pad and piston as well as actual brake coolers which carry heat out to an external heat sink...
this is why racecars have ducts and vents to keep cool air flowing over the brakes...
post #6 of 15 Old 06-30-2010, 09:27 PM
post #7 of 15 Old 06-30-2010, 09:46 PM
Superswire's Avatar
i don't think it would be that from what hes saying though, if it was the master cylinder it would do it cold too...if he pumps it and they work fine sitting still after pumping repeatedly then only fade after they heat up, then work again when cold its almost definately going to be hes boiling the fluid...in other words, it would stay spongy or would get spongy just sitting there and pumping them, because that would mean the fluid is getting past the master cylinder check valve or piston
did you know brake fluid actually absorbs water to an extent ? Weird huh ? anywyas that could be the problem, but with an aftermarket pad that has like 25% the coeficient or friction of a stock pad, you will have alot less heat and changing brake fluid although i never do so i'm a damn hypocrit, should be regular scheduled maintenance, ive heard and read that ALOT...
i would cheak your pads, clean your pads, calipers and rotors, top off your fluid and bleed your brakes just in case there was some air in there, then if like i said they work if you sit still and pump them aboout 30 times but once you ride like the wind and brake hard they fade then go back again when cool, you are definately boiling or have contaminated fluid...
if they fade without a spongy pedal it usually meanse you are 'glazing' your pads or heating them up to the pont where they were formed at, in that case your lever will be stiff still, it will just fell like your brakes have oil on them or something...
belive me, i did my homework on at a young age, never had a problem on the dirtbikes, but when i got my first car and the brakes got spongy and started smoking, i knew i had to learn something, lol
post #8 of 15 Old 06-30-2010, 10:37 PM Thread Starter
scrawny's Avatar
im sure theyre getting hot. brake fade, just the materials/calipers/rotors/fluid getting hot and becoming less efficient.
i was just wondering if anyone had tried a different adjustable brake lever that you could get more push on the piston if the front master cylinder thats all whew~
08 700xx
05 Ruckus
04 450r
86 Fat Cat
86 350x
81 250r
72 CB100
scrawny is offline
post #9 of 15 Old 06-30-2010, 10:52 PM
Anything that radiates heat away from the calipers and cools the fluid will help you. Stainless lines will help a little with that heat dissipation.
post #10 of 15 Old 06-30-2010, 11:03 PM
Superswire's Avatar
well why didnt you just sayso...
honestly, more pull, clutch or brake is never a bad thing...
