are there narrow and tall version maxxi razr? - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 07-03-2010, 04:50 PM Thread Starter
sicksnake's Avatar
I just bought 23/7/10 razr and 22/11/10 for the rear on itp pro series and the fronts are fine, but the rear are skinny and tall??? is this normal.? im ordering 20/11/10 and selling these . They are brand new just not my taste.
sicksnake is offline
post #2 of 15 Old 07-03-2010, 04:55 PM
You got a pic of them?
post #3 of 15 Old 07-03-2010, 05:01 PM
Yes this normal because you are putting a 11" wide tyre on a 7" wide rim.
post #4 of 15 Old 07-03-2010, 05:31 PM Thread Starter
sicksnake's Avatar
Huh? any time i ran a 20/11/10 never had issue. Is there a different size 10" rim for back i can order then?
post #5 of 15 Old 07-03-2010, 05:45 PM Thread Starter
sicksnake's Avatar
i will
post #6 of 15 Old 07-04-2010, 11:16 AM Thread Starter
sicksnake's Avatar
63 views and no input??? All the razr users??? EPIC FAIL
post #7 of 15 Old 07-04-2010, 12:41 PM
Where's the pic that EEHonda asked for? I have no idea what you mean, skinny and tall? Seems to me it is just a looks thing. What you think is skinny and tall may be normal to someone else. The only difference between a 22x11x10 and 20x11x10 tire is the one is 2" larger in diamter. They both should be close to the same width. I don't really know what type of "input" you are expecting.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #8 of 15 Old 07-04-2010, 02:09 PM
Doug
When you put an 11" wide tyre on a 7" wide rim the tyre width is decreased to about 91/2" and because it is narrower it causes the tyre to balloon and increases overall diameter.
I have a 20x11x10 Kenda Klaw on my ITP rim and it made it 221/4" diameter.
Even putting this tyre on the 10x8 rim the tyre becomes 10" wide and 211/2" in diameter.
I hope you understand this.
post #9 of 15 Old 07-04-2010, 02:33 PM
skier207's Avatar
There are lots of people like you that have questions. So they look through the threads. Hence you get views. But no info. Not epic fail.
I am not sure I understand your question.
I think what your asking is why is the tire tall and narrow. Like Baxter stated the ITP 10 wheel is only 7" wide. When you mount a 11" tire on that wheel it will tend to look narrower than say if you mount it on say a 9" wide rim. The tread width is the same but the section width (section width is the widest part of the tire) is wider on the wider wheel. When a wider tire is mounted on a narrow wheel the tread tends to want to crown out, which gives the tire a more narrow appearance. The only way that I know of to get a wider wheel on the back of this machine is to move the offset out which changes the load on the suspension, wheel bearings and handling characteristic's. Which is a whole other topic. See thread>https://www.club700xx.com/vb/showthread.php?t=4177
I hope this helps.
skier207 is offline
post #10 of 15 Old 07-04-2010, 04:14 PM Thread Starter
sicksnake's Avatar
I hope this helps.
Yes it does thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! now when you order a 10" rim can you specify the different width? actually they dont look as narrow here as they came with 17# air in them and i lowered to 7 #
