Help! How to get the front bumper off? - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 01-15-2011, 05:45 PM Thread Starter
trx700's Avatar
waving Help! How to get the front bumper off?
I searched everywhere for an answer to this question. I know I read it somewhere on how to remove the tight bolts on the front bumper. I could not find a thread on this. Two are stripped now. I sprayed them and still could not loosen them up. What is the easyest way to get them off?
2008 Black & Red TRX 700XX
trx700 is offline
post #2 of 11 Old 01-15-2011, 08:30 PM
Overlord's Avatar
Front Bar
Mate, I presume you mean the bolt heads are rounded and the threads are ok, the front bumbers are worth nothing, get the angle grinder out cut the bolt heads off, then get some vice grips and get the threaded end out. I suppose you could stuff around with easy outs but just hack the bar up and throw it away.
Man sorry if this sounds over the top but the bars are worthless. I dont mean to be a smart arse but make sure your undoing them the right way. Mine came straight out. Sounds like Honda might have put some lock tight on em.
HMF Bill Ballance full system with HMF controller, Pro design Filter and billet adaptor,
Fox Evolve Gen 2 with Houser +.75 arms,
Fox Podiums with Shock Pro skull covers,
OMF re-enforced front and rear with Kenda XCF up front and of course Kenda Kutter's on the rear,
Trail Tec bars, clamps and dash.
ASV Lever,
Braided lines and billet clamps,
Moto Active nerfs and Bumper,
AMF Graphics
OZlink gets his Kutters from me
Overlord is offline
post #3 of 11 Old 01-15-2011, 08:44 PM
Have you tried shocking them with a flat punch and hammer? I would have thought that those bolts would have twisted off before the head rounded off.
Depending on the bumper you have, it may be easier to center punch the bolt head and drill the head off rather than grind it. Just depends on how recessed they are. I would definitely try shocking them first, maybe a good 6 point socket on an impact would do it.
post #4 of 11 Old 01-16-2011, 01:43 PM
blk84's Avatar
I just put on a PRM desert II bumper and my stock bolts came out easy. However, my buddy has an XX and his did not come out. He drilled them out. That's what I would suggest.
08 700xx aka hillclimber
"If you want something done right, do it yourself"
Dominated...
SW, PA
Wellsville, OH
Buffalo Mtn, WV
Little Coal River, WV
Bearwallow, WV (every blk/red trail)
Rockhouse, WV (every blk/red trail)
Indian Ridge, WV
Pinnacle Creek, WV
blk84 is offline
post #5 of 11 Old 01-16-2011, 03:20 PM
Send a message via MSN to Gravyking
No problemo!
Come of easy.
Gravyking is offline
post #6 of 11 Old 01-16-2011, 03:28 PM
Overlord's Avatar
Boys my way is aggresive but you get the bar off in 5min flat, this way is good if you dont care about the stock bar.
My mate hit a tree bent two bolts and the mounting tabs. He stuffed around for hours trying to save the bar, while his nice new Moto Active bar was there smilling at him. He admitted defeat gave the job to me. I had his bar fitted in less than 15min. I got to admit the stock bar was in 4 peaces when I finished.
ASV Lever,
AMF Graphics
Overlord is offline
post #7 of 11 Old 01-16-2011, 10:14 PM Thread Starter
trx700's Avatar
Thanks for the idea's. I purchased some bolt extrator sockets today. I will give that a try before I try and destroy the front bumper. I do own a sawall. I needed a push to not save the old cheap bumper. I realize that sometimes you have to destroy it to improve it.
trx700 is offline
post #8 of 11 Old 01-17-2011, 07:00 PM
did u heat up the frame. thats the first thing u shoulda tried
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #9 of 11 Old 01-17-2011, 08:53 PM
I was trying to get the caliper pins out of my rear disc brakes on my 2001 Chevy Z71 the other day. A poor attempt at rear discs by GM in my opinion. Anyways had them in the vice trying to get them out and my propane torch was out. Mechanic friend brought his by and said, "If you don't hold it right it will let you know." Asked him what he meant and he said it would be obvious. Used it for a couple minutes then WOOSH, like a hand explosion to the 27th power. I had him hold it right on the next one and it did the same thing to him, pretty exciting.
post #10 of 11 Old 01-17-2011, 10:43 PM
lmaoooooo .... commeon i gota keep qiuet so my ma n pa dont wake up..... my cam chain poped off... no damage
-uni
-primary drive 13t
-pclll
-skyjacker 6'' lift
-sct 100hp tune
