Teixeira Anti-Vibe Steering Stem & Precision Shock & Vibe Handlebar Clamp COMBO - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 02-20-2012, 11:18 AM Thread Starter
GAZ69OK's Avatar
I just had a long conversation with ED @ Teixeira... Nice guy. Very helpful.
The plan:
CCP Steering Stabilizer
Black SS Brake Lines
Easton EXP M99 53/RM Mid Bars
ODI Rouge Grips
ASV Shorty Levers
Emgo Pro-Guard Reinforced
I don't another broken wrist.
Have:
ODI Rouge Grips
ASV Shorty Levers
Requesting a package deal from Ed @ Teixeira:
My questions:
1) Will the stock throttle and clutch cables be sufficent or do I need Motion Pro +2 throttle and clutch cables?
2) Do I need extended length SS brake lines?
3) Should I get the Fasst Co. Anti-Vibration Inserts?
4) Do I need Teixeira's brake line holders?
5) I have read about the "T" bracket for the brake lines needing to be bent or cut and re-welded for the CCP Steering Stabilizer. How much more of a problem is this going to be with a greater diameter stem? (1.25")
6) Where should I relocate my indicator lights to?
Anything else I have missed, ideas or thought, please comment.
'08 TRX700XX List 'O Mods:
13t Drive
ASV Shorty Lever(s)
MQ Brake Block
Honda Racing Front Bumper
Alba Pro Elite Nerfs (Chrome)
J-n-J Full Skids
Uni Filter
Streamline SS Brake Lines
MotoGrip Black Skulls
Offensive Fender Warning Tags
Black Shock Covers
FST Radiator Guard
Relocated Indicator Lights
Maier Top Cover
Tusk Gas Cap
GAZ69OK is offline
post #2 of 8 Old 02-20-2012, 06:20 PM
#1) Stock clutch cable should be fine. I can't help you out on the thumb throttle cable as I run a Motion Pro twist throttle setup and this works without a extended cable.
#2) I run 52" twin lines over the standard 3 line "T" setup. I found this to work better in both instalment and helps out with the front brakes overheating.
#3) No , they are not needed. The Teixeira Tech antivibe stem plus PRP anti shock and vibe clamps with Easton bars ,will reduce vibration about 95-98%. The rest is in the grips you choose. I run Pro Taper Pillow Top grips. Again this is my expieriance and I have never seen or tried ODI grips.
#4) I forgot to order mine ,when I ordered the a-arms .
#5) see #2 and order the stabiliser with a Yamaha stem clamp.
#6) under the front hood.
Also remember to ask Ed for some CRF rubber dampners for the stem or get them from you local Honda dealer. Something else ,I forgot about.
I have been running something similar and would run the same ,what ever make of quad ,I run in the future. You'll never find a better setup.
post #3 of 8 Old 02-20-2012, 09:07 PM Thread Starter
GAZ69OK's Avatar
Baxter,
Thanks for the respond. I was gonna PM you about this because I saw your setup. https://www.club700xx.com/vb/showpost...0&postcount=18 It is very similar.
What Easton bar do you have?
You have and idea of the bar height and sweep/pullback differences between what you're running versus stock? With my setup, Ed was estimating something like .75"-1" height gain over stock...
I was watching a few of your racing videos and it looked like your bars were a low bend? Does the bar location force a up front riding style?
2: I am on the stock a-arms. Does the 52" length for the twin lines still apply? Are yours Galfer or Streamline? I would imagine it makes it much easier to reverse bleed twins rather than the 3 line.
CRF rubber dampers? Should I pick up the Lonestar Racing 450r Ali stem clamp or Red & Black said there was teixeira tech anti vibe clamp?
Hopefully I can get it all sorted and ordered tomorrow!
13t Drive
ASV Shorty Lever(s)
MQ Brake Block
J-n-J Full Skids
Uni Filter
Black Shock Covers
FST Radiator Guard
Maier Top Cover
Tusk Gas Cap
GAZ69OK is offline
post #4 of 8 Old 02-21-2012, 10:31 AM Thread Starter
GAZ69OK's Avatar
I pulled the trigger with Ed on the +2 stem, the shock & Vibe, the Easton Bar, and some brake line holders. I am gonna re-use the stock stem clamp. The slick Lonestar racing clamp would never be seen...
Ed says you are running 1.25"-1.5" extended a-arms. So I will reduce the twin front lines to 51"? Ed and I came to a consensus on the 51" dimension, but I think it is the blind leading the blind. Can you comment, Baxter?
I am really REALLY not looking forward to taking the J-n-J skids off to gain access to the bottom of the stem!!
13t Drive
ASV Shorty Lever(s)
MQ Brake Block
J-n-J Full Skids
Uni Filter
Black Shock Covers
FST Radiator Guard
Maier Top Cover
Tusk Gas Cap
GAZ69OK is offline
post #5 of 8 Old 02-22-2012, 10:51 AM Thread Starter
GAZ69OK's Avatar
I went ahead and ordered the 52" twin lines in black from Streamline.
13t Drive
ASV Shorty Lever(s)
MQ Brake Block
J-n-J Full Skids
Uni Filter
Black Shock Covers
FST Radiator Guard
Maier Top Cover
Tusk Gas Cap
GAZ69OK is offline
post #6 of 8 Old 02-22-2012, 06:58 PM
The 52" will work well with the stock a-arms, I am running +1.25" Ed's a-arms and they are only just long enough with lower than stock handlebar height. About 3/4" lower.
post #7 of 8 Old 03-05-2012, 11:09 AM Thread Starter
GAZ69OK's Avatar
13t Drive
ASV Shorty Lever(s)
MQ Brake Block
J-n-J Full Skids
Uni Filter
Black Shock Covers
FST Radiator Guard
Maier Top Cover
Tusk Gas Cap
GAZ69OK is offline
post #8 of 8 Old 03-05-2012, 11:11 AM Thread Starter
GAZ69OK's Avatar
The Emgo handguards would not work with the tapered bars.
13t Drive
ASV Shorty Lever(s)
MQ Brake Block
J-n-J Full Skids
Uni Filter
Black Shock Covers
FST Radiator Guard
Maier Top Cover
Tusk Gas Cap
GAZ69OK is offline
