YFZ450R Shocks on the 700xx - Club700XX - Honda TRX700XX Forum
post #1 of 13 Old 03-04-2012, 11:22 PM Thread Starter
Will they work? They seem to be the correct lengths at 18.25" The mounts don't worry that much as I can have new mounts made. Anyone have an opinion on these before I throw money at something that may not work?
post #2 of 13 Old 03-05-2012, 07:46 AM
The yfz450r shocks are wider at the mounts than Honda's you'll just have to grind them down some but no biggie. They are awesome shocks, some of the best stockers out there, if you have them revalved/resprung later on you will be even happier. Ithink just the top mounts have to be grinded though. You should be able to get a set of these for about $300
2006 Raptor 700
post #3 of 13 Old 03-05-2012, 07:50 AM Thread Starter
the set i found is $350 shipped.
i think the bottom mount is the same. It's just the top mount that needs modified
I just want to make sure that it's not going to be lower than it is factory.
post #4 of 13 Old 03-05-2012, 09:08 AM Thread Starter
Someone PM'd me about these asking why i'd pick these over the DS shocks - can anyone else post up if they think they're better or not? I know the DS are cheaper and yellow :puke:
post #5 of 13 Old 03-05-2012, 10:06 AM
The DS shocks are ok but the 450R shocks are much better according to a friend that rebuilds shocks, they are as good as Elkas stage 2 but with hi/lo speed compression and rebound adjustability, they are also kashima coated with 9.8in of travel vs the 9.5in on the DS shocks.
2006 Raptor 700
post #6 of 13 Old 03-05-2012, 10:09 AM Thread Starter
Am I correct in that they're same length of stock shock we have?
post #7 of 13 Old 03-05-2012, 12:13 PM
They are 18.25in eye to eye, is that the length of the stock 700xx shocks? Just make sure they are the yfz450R ones and not the yfz450x as the x ones are 16.75in long
2006 Raptor 700
post #8 of 13 Old 03-05-2012, 12:28 PM
Here is what I did, mine were revalved and resprung and they are awesome. The ones that I have are shorter than the xx but they work great.
https://www.club700xx.com/vb/showthread.php?t=7370
post #9 of 13 Old 03-05-2012, 01:11 PM Thread Starter
Looks good, but i dont want it lower. I'm thinking i may pull the trigger on these.
post #10 of 13 Old 03-05-2012, 03:04 PM
I measured the stock front TRX700XX shock,unfitted length of 17 3/4 inches, if that helps.
mervex
mervex is offline
