08 700xx - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 03-18-2012, 06:00 PM Thread Starter
08 700xx
I recently bought this bike and i love it.Although if any body can help me with a question about the rear tires.The rear tires seem to be toed out,and the inner tread is wearing more than the outer.Is this normal wear for this bike because it has independent rear suspension or is there an adjustment that i can make to fix this problem.
DTRESHMAN is offline
post #2 of 7 Old 03-18-2012, 06:52 PM
IDK about repair, but i'd say not normal. At least my oem tires wore even and so far the 2nd set it too. Could be previous owner jumped it alot?
post #3 of 7 Old 03-18-2012, 07:06 PM Thread Starter
Do your tires toe out on your bike?
post #4 of 7 Old 03-18-2012, 07:43 PM
No , I would say something is wrong on the rear. Check for play on the a arm bushs etc.
post #5 of 7 Old 03-18-2012, 07:45 PM
Also does the rear end "snake" in 4th and 5th gear ?
post #6 of 7 Old 03-18-2012, 09:23 PM
DTRESHMAN,
The tires on my XX appear to be tilted in at the top until I get on the machine then they are perfectly aligned and tires are wearing correctly. They are not towed in that I can see. I believe there are measurements on that issue within the Service Manual. If you don't have that manual go to the "HOW TO" section of this forum and down load it for free. Hopefully others can be more helpful.
post #7 of 7 Old 03-20-2012, 10:56 AM
Try this test...
Jack up back end so wheels are off the ground and disconnect the shocks from the a-arms. This removes the load. Try to wiggle the wheels to toe in and toe out. Also try to wiggle the wheels to check for play in and out at top of wheel. You're checking for play in bushings and ball joints. Check over a-arms for damage. Bushings and/or ball joints should be replaced if there is too much play.
