dwt beadlock / rancher 420 hubs - Club700XX - Honda TRX700XX Forum
 1Likes
post #1 of 13 Old 03-20-2012, 03:42 PM Thread Starter
can anyone tell me what offset of dwt beadlock 10"rims will work on the back of the xx...want to keep it wider than stock by about 2".....will be changing to rancher 420 hubs..wheels i have in mind are like these... http://www.ebay.co.uk/itm/DWT-Alumilite-YELLOW-LABEL-ATV-Front-Beadlock-Wheel-10x5-3-2-4-156-Yamaha-450R-/380394491084?pt=Motors_ATV_Parts_Accessories&hash= item5891474ccc
elioquadsport is offline
post #2 of 13 Old 03-21-2012, 02:30 PM
Our stock offset is 5:2 and you'd need to go with a 4:3 offset to be able to use 10" rims.
post #3 of 13 Old 03-21-2012, 02:53 PM Thread Starter
is this also the same with the rancher hubs
post #4 of 13 Old 03-21-2012, 05:15 PM
What tyres are wanting to use ?
post #5 of 13 Old 03-22-2012, 02:16 AM Thread Starter
bearclaws on the rear and rzr on the front
post #6 of 13 Old 03-22-2012, 10:32 AM
Even though I don't know about rancher hubs... I'd say that the hubs themselves are not the item you need to change offset for... It's in getting necessary clearance between the rim and the a-arm that's the issue.
post #7 of 13 Old 03-22-2012, 10:54 AM Thread Starter
i wont order wheels till i see the hubs on the quad...but i was thinking 4+3 offset at the rear..open to suggestions though...like the quad the way it is at the moment..about 2" overall wider than standard...the wheels i have at the moment on the standard hubs are 4+3 offset with 10" wheels...also 12" wide tyres
post #8 of 13 Old 03-23-2012, 11:28 AM Thread Starter
hubs have a 4 weeks back order..can anyone tell me if i would be safe enough to order the dwt wheels with a 4+3 offset for the rears
post #9 of 13 Old 03-23-2012, 07:20 PM
A DWT 10x8 :4+3 is only availible in a 4x144mm stud pattern If you want to run rancher hubs which is a 4x110mm stud pattern then the only rims availible are 10x8 in a 3:5 offset.
post #10 of 13 Old 03-25-2012, 08:40 AM Thread Starter
lee...could you send me a link to this size..cant seem to find it..didn't know you could get the rears in a 144pcd x 10"
