Can't get bent tie rod off. - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 04-15-2012, 07:46 PM Thread Starter
Is there a trick to this?
I am trying to replace my bent tie rods, but I cant get the ends off of the bike. I pulled the little pins out, but when i try to get the nut off of the end where it mounts to the a arm, it just spins, and there is nothing for me to grab on the underside to keep it from spinning. is there something under the bushing? this seemed like it was gonna be so simple, and I'm stuck right off the bat.
08 Honda 700xx
Installed
Britalican is offline
post #2 of 6 Old 04-15-2012, 09:34 PM Thread Starter
never mind. I went back out there right after i post this and figured it out. replaced both bent tie rods, but now I think my steering stem is bent too. son of a bitch.....
08 Honda 700xx
Installed
post #3 of 6 Old 04-15-2012, 10:11 PM
traitor08's Avatar
May I ask how you managed to "mess up"
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #4 of 6 Old 04-15-2012, 11:35 PM Thread Starter
well it really was simple. I was just impatient. There is a little washer right on the under side of the mount with flat sides that u hold in place with a wrench. I tried that right away, but it didn't appear to be doing anything after a couple turns so i thought I was wrong, and came in and made this post, but yeah it really was easy. next is replacing the bent steering shaft.
08 Honda 700xx
Installed
post #5 of 6 Old 04-24-2012, 06:43 PM
did both on predator 90 , left wheel was turnin left , and the right turning right, it was weird , I unbent them, almost like new ,
ulfheonar is offline
post #6 of 6 Old 04-25-2012, 12:32 AM Thread Starter
yeah, thats how mine was too.
08 Honda 700xx
Installed
