razr : 20 on 10 , or 22 on 11 inch rims ? - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 04-18-2012, 04:05 PM Thread Starter
i just bought bearclaw 24-9-11 , oh what a big mistake I did , wheelies and acceleration , rear lifting are a lot harder . ill spend some more time to ride them to be sure , im thinking of buying razr , as most recommend , should I get 20 on 10 inch rim ?( but they are 4 ply) i dont have smaller sprocket yet but im doing a lot of technical wood trail , maybe it would be better 20 inch tires for slow speed . ?
ulfheonar is offline
post #2 of 11 Old 04-18-2012, 05:47 PM
boost addict's Avatar
I run the gbc x-rex 20x11-10 6ply. The are basically the same tire as the razr2 tire but cheaper in price.
http://www.gbcmotorsports.com/xrex-p-129.html
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #3 of 11 Old 04-18-2012, 06:27 PM
May not be able to answer this one but what size of tire did you have on the front ?
post #4 of 11 Old 04-18-2012, 08:07 PM Thread Starter
I have x-rex 23 on front , great tires , I also have xrex 20-11-9 almost new from when I had my 400ex , great tires but 400ex wasnt powerful enough for them , too heavy I guess
post #5 of 11 Old 04-18-2012, 08:34 PM
traitor08's Avatar
22 on 11.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #6 of 11 Old 04-19-2012, 07:22 AM
post #7 of 11 Old 04-19-2012, 09:56 PM
Get 10 inch rims and run 22's the stock rims are junk
post #8 of 11 Old 04-20-2012, 07:58 AM
Dune64's Avatar
I would try a 12 or 13 tooth front sprocket with your current 24's before discounting the tires. this should put your power band back in a better range. The taller tires have the same effect as raising your gear ratio, so it just makes sence to go with a lower count sprocket, besides they are less than 20 bucks delivered to your door.
08 700XX
07 Long Travel Rhino
07 Suzuki LT2550
06 Kido's Chino 70cc quad
04 Rancher 350ES
04 Rancher 350
91 Jeep YJ
81 ATC 70XX
Dune64 is offline
post #9 of 11 Old 04-20-2012, 10:05 AM
Might I suggest 22" Razr on the stock 11" rims and add a 13t... better low end torque for tight stuff at low speed. Will reduce top end a bit, but not that much. Beat the hell outta the stock rims first, then replace with better rims later... (DWT or OMF)
post #10 of 11 Old 04-20-2012, 03:54 PM Thread Starter
is the front sprocket same as the one on 400ex , i will buy the 13t , it will run better for now , i was thinking to replace the rear with douglas , as I did with the front .
Tags
razr
