staying with stock rims, which tires? - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 04-23-2012, 11:55 AM Thread Starter
I am going to stick with stock rims, I'm leaning towards getting
Kendra Bear Claw 23*8*11 for my rears
and was wondering if i should also up the size for my front tires as well or stay at the stock size tire.
was leaning toward
Kendra Kutter either 22*7*10 or 21*7*10
or
Kendra Bear Claw 22*8*10 or 23*7*10
any suggestions??
downazziggy is offline
post #2 of 10 Old 04-23-2012, 12:53 PM
allnew2me's Avatar
I love my new Kutters 22 front and back
allnew2me is offline
post #3 of 10 Old 04-23-2012, 04:29 PM
grafixghost's Avatar
I'm in the same boat looking at the kutters and klaws. Ride alot of rutted trails and some deep mud.
2008 Honda TRX700XX
UNI Air Filter
13 tooth sprocket
Alba Racing Nerf Bars
L8TON 11/16" Sway Bar
Powerform Pro Skid Plate
ODI Rougue Grips
Rear Sport Rack
Pro-Taper Contour ATV mid bend/Trail Tech clamp
grafixghost is offline
post #4 of 10 Old 04-23-2012, 06:29 PM
allnew2me's Avatar
I'm new at the quad thing, but the traction of these tires are insane. I can say that on wet grass they don't hook up as well as wet dirt if that helps. The klaws look beefy just didn't know what kind of ride I would get at 40 to 60 mph.
post #5 of 10 Old 04-24-2012, 07:39 PM
was leaning toward
or
any suggestions??
where do you see the bear claw listed in that size?
fraiolib is offline
post #6 of 10 Old 04-24-2012, 08:29 PM
What size you looking for?
http://www.tiresnstuff.com/kenda-bearClaw.html
post #7 of 10 Old 04-24-2012, 09:08 PM
What kind of riding do you do? I had the bear claws and I wasn't a fan unless it was for only super sloppy stuff. And even then I was only slightly better than what you could do with a razr or kutter. And you loose more ability to slide the rear around and end up with more front end push
post #8 of 10 Old 04-24-2012, 09:53 PM
ooooo i was looking at claw tires and didnt see any 11 inch tires, bear claw is different than just a claw got it
fraiolib is offline
post #9 of 10 Old 05-01-2012, 04:12 PM
I bought claws 2 weeks ago , 24-9-11 , they are very cheap tires , I dont like them because dont slide at all when cornering , cant do donut , even with 13T front,acceleration and handling are decreased very much only to get more clearance and mud traction. I consider now to buy 10 inch with razr , and keep bear claws as spare .11 inch douglas wheels/tires razr are about 40% more expensive than 10 inch .
ulfheonar is offline
post #10 of 10 Old 05-02-2012, 06:16 PM
The Bear Klaw 23x8x11 are good in the thick slow stuff, if you hit 4th or 5th then they kinda fishtail alot espicailly on hard pack trails. If you can get the Kenda Kutter 22x9x11 then get them. Match them with the Kenda Klaw XC 22x7x10 and you would have perfection.
