Will the Kutters increase 700XX width? - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 04-25-2012, 03:18 PM Thread Starter
grafixghost's Avatar
I am thinking about getting a set of Kenda Kutters 22x9 11 for the back of my 700XX but I would like to know if it would increase the width of the bike? My trailer is pretty small and with stock tires I only have about an an inch on each side when pulling my bike onto the trailer.
Thanks
2008 Honda TRX700XX
UNI Air Filter
13 tooth sprocket
Alba Racing Nerf Bars
L8TON 11/16" Sway Bar
Powerform Pro Skid Plate
ODI Rougue Grips
Rear Sport Rack
Pro-Taper Contour ATV mid bend/Trail Tech clamp
grafixghost is offline
post #2 of 4 Old 04-25-2012, 07:25 PM
I have the same issue, but my kutters just barely fit with like a half inch on each side. so they are a little wider, but you should still be ok, if you have an inch on each side now. my sand stars rub their way into the trailer.
08 Honda 700xx
Installed
Britalican is offline
post #3 of 4 Old 04-26-2012, 03:21 PM Thread Starter
Thanks for the info, I should have got a bigger size trailer but was trying to save some money.
2008 Honda TRX700XX
UNI Air Filter
13 tooth sprocket
ODI Rougue Grips
Rear Sport Rack
post #4 of 4 Old 04-26-2012, 05:45 PM
Yeah I got mine for the same reason. Its nice for fuel savings, and its easy to tow though. Plus I have the luxury of cool friends with bigger trailers that will let me borrow them whenever I need.
08 Honda 700xx
Installed
