Suspension - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 04-27-2012, 12:01 PM Thread Starter
Suspension
I am hopping to get rid of the stock suspension on my 700xx. Could anyone help me decide what I should replace the suspension with. Preferably on the less expensive side but also good.
Ultimate700xx is offline
post #2 of 7 Old 04-27-2012, 12:34 PM
I have Elka shocks front and back. Some members use Fox shocks. Neither is cheap. You could use DS450 shocks on the front... they require a bit of grinding to the top eyelet to fit, but is a cheaper way to go.
post #3 of 7 Old 04-27-2012, 03:21 PM
YFZ 450 shocks are good as well but they will lower your bike down a bit.
post #4 of 7 Old 04-27-2012, 05:55 PM
700xxchris's Avatar
has anyone seen the new stage 5 elka shocks they are sick
700xxchris is offline
post #5 of 7 Old 04-27-2012, 05:58 PM
priesty's Avatar
LTR450 shocks will fit also, with a little tweaking.
Happy trails..........
Priesty.
2008 700xx,
My Flickr sets:
priesty is offline
post #6 of 7 Old 04-27-2012, 06:55 PM
How are your LTR450 shocks working for you Priesty.?
Mine are great with a few small adjustments. It is now so obvious that with kutters and front shocks with proper damping that the trx is a killer on the trails!
Mine is stock apart from that and most guys can,t keep up!!
mervex
mervex is offline
post #7 of 7 Old 04-29-2012, 09:11 PM
priesty's Avatar
mervex
Yeah just tested them out this weekend in fact. Definitely an improvement, but still need to fine-tune the fast compression as choppy terrain was very harsh, however the slow compression seems fine, less body roll & larger hits were all ok.
Do you know which adjust is for fast comp, & if I adjust that will I need to re-adjust the rebound as well ? PM me your settings if u can & I might use them as a start point.
cheers......
Edit: After a bit of research, it appears that there is only slow compression adjustment & the nut is just a locking mechanism, can anyone confirm this ?
Priesty.
2008 700xx,
My Flickr sets:
priesty is offline
