rear shock adjustment - Club700XX - Honda TRX700XX Forum
post #1 of 13 Old 05-28-2012, 01:39 PM Thread Starter
does anyone know if there is a way to take out some of the re-coil on the rear shocks over bumps/woops? i almost get bucked off if i hit them too fast or hard, even hanging over the back going over them. it seems that with less rebound (extension time) it would be better. i would like to leave them stock if possible. adding nitrogen or something? i have tightened the rear springs a little would cranking them all the way down help?
klund is offline
post #2 of 13 Old 05-28-2012, 01:54 PM
Our stock shocks are crap with the only adjustment being pre-load. This is why I upgraded my shocks to Elka. I can adjust my rebound so I don't get bucked around. Good shocks make a world of difference... once you learn how to adjust them for what, that is. As far as I know, there really isn't a way to "fix" crappy shocks.
post #3 of 13 Old 05-28-2012, 04:57 PM Thread Starter
any idea about cost on elka shocks and springs?? front and rear?
klund is offline
post #4 of 13 Old 05-29-2012, 10:16 AM
Xstriker's Avatar
http://www.elkasuspension.com/?q=node/19
You can also look at the other stage options, this is for the stage 2 shocks.
08 TRX 700XX
HMF Full Performance Exhaust
EHS Programmer
11/16 L8ton Swaybar
Skat~Trak Haulers 20X10X10
Alba Pro Elite Nerfs
Trail Tech Vapor Speedo/odom
Xstriker is offline
post #5 of 13 Old 05-29-2012, 12:07 PM
The Elka stage 2 only comes as a piggy back and that won't work for our rear... you'd need remote rezzies. I have stage 2 plus compression fronts (not offered anymore) and stage 3 rears (also not offered anymore) I paid something like $2,300.00 for my setup direct from Elka (Did I give you a heart attack yet?)
post #6 of 13 Old 05-29-2012, 01:26 PM
Would stage 1 elka shocks in the front and stage 2 in the rear be good
GA 700xx kid is offline
post #7 of 13 Old 05-29-2012, 01:57 PM
Stage 1+R would be better for the front... But, you can't use Stage 2 on the rear as they only come as a piggy back rezzie. The rear of our quad doesn't have room where the piggy back rezzies would need to go. The only kind of rezzie that fits would be a remote rezzie type. Excerpt from Elka catalog in attachment. For the front, the DS450 shock would be better than a basic stage 1 Elka shock. Note: Slight mod to upper eyelet needs to be done to DS450 shock.
post #8 of 13 Old 05-29-2012, 08:09 PM Thread Starter
is there any stock shocks from other bikes that would be better than what we have front or rear without having a heart attack looking at the price or giving an arm or leg to buy them?
klund is offline
post #9 of 13 Old 05-29-2012, 08:15 PM
There's a few for the front ,I'll find some threads on the subject. If you are having problems with the rears ,then kinda guessing ,200lbs+ ish in rider weight ?
post #10 of 13 Old 05-29-2012, 08:18 PM
Xstriker's Avatar
ROFL yea KEVIN u fat ass....
Fronts - DS450 Shocks Rears- I don't know
08 TRX 700XX
EHS Programmer
11/16 L8ton Swaybar
Xstriker is offline
