Sprocket Help - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 07-20-2012, 04:43 PM Thread Starter
Sprocket Help
Ok so I recently put 24" Kenda Baer Claws and 23" Kenda Kutters on my 700. Defintely need to do some re-gearing. Was hoping to only have to redo the front sprocket but Im not sure what size I need for more low end torque. Im guessing a 13 tooth.
Also do I need a new chain when doing this?
Collie's700xx is offline
post #2 of 5 Old 07-20-2012, 05:02 PM
700xxchris's Avatar
no new chain needed if you feel liek you need a chin replace it i run the 13t and i love it
700xxchris is offline
post #3 of 5 Old 07-21-2012, 04:31 PM
BuckeyeXX's Avatar
Yep a 13t will help with the low end grunt. I run stock tires and couldn't be happier with it. It helped on the trails so you don't have the constant shifting especially if your running the bigger tires.
08 700XX Black/Gray
01 90 Yerf Dog
BuckeyeXX is offline
post #4 of 5 Old 07-23-2012, 01:49 PM Thread Starter
Should I go with a 13t or 12t with the 24 inch rear tires?
post #5 of 5 Old 07-23-2012, 08:02 PM
BuckeyeXX's Avatar
Well I haven't ever run a 12t so I can't really give advise on it but I really like the 13t on mine but that's with stock rear tires. The 12 might be better with the bigger 24in tire. I think if you drop down to the 12 you will need to take a link out of the chain.
08 700XX Black/Gray
01 90 Yerf Dog
