what should i get - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 08-02-2012, 02:56 AM Thread Starter
what should i get
Should i get houser desert a arms or fox podium rear shocks ??? ALL input appreciated !!!
Do the houser a arms help the ride ??? are podium x's that big of a difference against stock.
by the way I wiegh 140 pounds.
700xxracer is offline
post #2 of 15 Old 08-02-2012, 11:50 PM
You want front or rear Houser arms? What suspension mods do you currently have?
post #3 of 15 Old 08-03-2012, 12:54 AM
Shocks first the stock shocks leave a lot to be desired
09 XX
13T, Yoshi exhaust, Dynajet programmer, PRM bumper, PRM grab bar, Tusk head lights, OMF rear beadlocks, Douglas bead lock fronts, Kenda Kutter 22x7 fronts.....I can't stop
jsnell is offline
post #4 of 15 Old 08-03-2012, 12:59 AM
You know you need new front shocks to use those a-arms, correct? They are a long shock arm, so the stock shocks won't work.
Could always get front a-arms and shocks and then revalve the stock rear shocks, would be a budget setup and should be a good improvement over stock.
Doug
EDIT: Just saw your other post and see you have Evol's on the front. After looking at Houser's shock specs, they may just work, would confirm with Houser that the extended and compressed lengths for the shocks you have would work with there arms. If they do, my suggestion would be to get the arms then revalve/respring the rear shocks. For the rears, check with Ceballos, he can recomend a guy in SoCal that can do the work.
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #5 of 15 Old 08-03-2012, 01:58 AM Thread Starter
the fox floats were meant for the houser arms when i bought them. They said there right. I just have to decide if i want new a arms for the front or get rid of the stock rear shocks and get fox podium x's.
post #6 of 15 Old 08-03-2012, 10:17 PM
I vote for the a arms then you gain camber and caster adjust and travel
500Rubie is offline
post #7 of 15 Old 08-03-2012, 11:38 PM
JBGILL06's Avatar
I'm not sure if you are racing or not, but if you are just aggressive trail riding, I would upgrade the rear shocks.
2008 Honda TRX700XX
*Power Commander V
*Pro Design Air Filter
*Elka Stage One Shocks
*Pro Taper Evo Bars
*Trail Tech Big Bar Clamp
*MSR Clutch Perch
*Powermadd Handguards
*ODI Rogue Grips
*IMS 5gal Tank
*Pro Armor XC Bumper
*PRM Full Skid Plates
*Maxxis Razr II Tires
*ITP Aluminum Rims
2007 Honda Rincon GPScape
JBGILL06 is offline
post #8 of 15 Old 08-04-2012, 12:54 AM Thread Starter
i dont know i mean i don't race but i do ride fast when i do. I like to do trails, desert and the dunes :/ Would i really notic a big difference with after market a arms ???
post #9 of 15 Old 08-04-2012, 01:39 AM
You would for sure notice a difference with the a-arms, the quad will actually turn and no more push since you can adjust the castor. Plus the extra width would be a plus also.
Biggest question is, what do you think of the rear shocks now? Do you think they work well or are they holding you back? As I said in my other post, I would get a-arms and revalve/respring the rears.
Doug
2005 TRX450R
1986 TRX250R
post #10 of 15 Old 08-04-2012, 02:57 AM Thread Starter
The problem is i wiegh 135 pounds. there okay i guess i just stand up to get thrue the rough stuff
