Handle bars and clamps - Club700XX - Honda TRX700XX Forum
post #1 of 21 Old 08-20-2012, 04:21 PM Thread Starter
Quoted: 5 Post(s)
I've been reading for a looong time about the handle bars, s/v clamp
but I'm still having a hard time deciding what to do with the handle bars.
I got the CCP steering damper ordered and what I'm not sure of is if I
should bite the bullet and order the Precision S/V clamp or try the
Trailtech clamp with the 1 1/8" bars. I'm trying to save a little cash here
but on the other hand I do have a $40 gift card to Rocky Mountain
to ease the pain of the S/V clamp.
My other issue is I want to replace the handle bars no matter what but I
have no idea what to go with especially when it comes to width, height
and pull back. Do I get low or medium rise bars? How should I determine that?
I'm actually leaning toward the Trailtech clamp and bars but I have a strong
feeling everyone is just going to say go with Precision S/V.
Will I need longer brake lines or cables or will they be long enough
once I remove the facotry guide brackets?
Thanks guys!
2008 Honda Trx700xx
2007 Yamaha Wolverine 450 4x4
2009 Raptor 90
2005 Polaris 50
Snowdog is offline
post #2 of 21 Old 08-23-2012, 11:06 PM
hard to say what bars you should get, its all just what you prefer, i really like the protaper windham bend. right now i have stock bars with a 1.6 in riser and that is as tall as you can go with stock brake line and clutch cable, motion pro makes a +2 cable and streamline has a very nice front brake line +2 kit, which i have both of them and a 3in riser to try soon.
fraiolib is offline
post #3 of 21 Old 08-24-2012, 10:00 PM Thread Starter
Quoted: 5 Post(s)
So after reading post going back to 2010 and my eyes going completely cross-eyed I kinda came up with a list of handle bars. One of the things I read which seems to be one of my problems is that I'm leaning forward on the bars and putting extra pressure on my hands. So I want to try and find a little taller bar with maybe a little more pull back, I think. I came up with this list of my choices.
It didn't seem to help one single freakin bit after all that research!
Pro Taper EVO's
cr high bend - 31.50 wide X 3.74 high X 2.45 pull back
Windham/RM Mid - 31.50 wide x 3.90 high x 2.13 pull back
Woods high bend - 31.50 wide x 3.74 high x 2.56 pull back
Pro Taper Coutour
atv mid bend 31.50 wide x 4.25 high x 2.21 pull back
atv low bend 31.50 wide x 3.74 high x 2.37 pull back
cr high bend 31.50 wide x 3.74 high x 2.37 pull back
cr med bend 31.50 wide x 3.23 high x 2.24 pull back
Windham MX 31.50 wide x 3.90 high x 2.13 pull back
Trail Tech
ATV high bend 31.10 wide x 4.21 high x 2.44 pull back
ATV mid bend 31.10 wide x 3.74 high x 2.44 pull back
ATV low bend 31.10 wide x 3.27 high x 2.44 pull back
Renthal Twinwall
Cr high - 31.29 wide x 3.74 high x 2.44 pull back
2008 Honda Trx700xx
2009 Raptor 90
2005 Polaris 50
Snowdog is offline
post #4 of 21 Old 08-24-2012, 11:20 PM
JBGILL06's Avatar
I have pro taper evo bars on my XX, and there isn't enough room for all of my controls. I have to take of my powermadd hand guards to make sure everything that needed to be there is, and it's still too cluttered.
2008 Honda TRX700XX
*Power Commander V
*Pro Design Air Filter
*Elka Stage One Shocks
*Pro Taper Evo Bars
*Trail Tech Big Bar Clamp
*MSR Clutch Perch
*Powermadd Handguards
*ODI Rogue Grips
*IMS 5gal Tank
*Pro Armor XC Bumper
*PRM Full Skid Plates
*Maxxis Razr II Tires
*ITP Aluminum Rims
2007 Honda Rincon GPScape
JBGILL06 is offline
post #5 of 21 Old 08-25-2012, 11:03 AM Thread Starter
Quoted: 5 Post(s)
Not what I wanted to hear since I need hand guards and a gps mount also on there.
2008 Honda Trx700xx
2009 Raptor 90
2005 Polaris 50
Snowdog is offline
post #6 of 21 Old 09-03-2012, 06:14 PM
i went with rox 2'' anti vib risers and flexx high bars... i was able to stay with stock break lines and throttle cable
robbyvaughn9 is offline
post #7 of 21 Old 09-03-2012, 07:45 PM
when i got mine it had pro taper SE atv high bars on them, i still have them on, at first i bought a 1.6in riser that i think power madd makes and that was as tall as i could go with stock cables, maybe the protape high bend bars are taller than stock idk
fraiolib is offline
post #8 of 21 Old 09-04-2012, 05:29 PM
warlock28's Avatar
Here is a thread on how the Trail Tech looks on mine.
https://www.club700xx.com/vb/showthre...?t=2168&page=5
2008 TRX700xx X 2
2003 Excursion V10 (Pull Toy)
warlock28 is offline
post #9 of 21 Old 09-05-2012, 10:00 AM
grafixghost's Avatar
I am in the same boat as you and just posted a new thread before I saw yours. The whole handlebar thing can be quite confusing. I would like to know what setups will allow us to keep the same cables?
2008 Honda TRX700XX
UNI Air Filter
13 tooth sprocket
Alba Racing Nerf Bars
L8TON 11/16" Sway Bar
Powerform Pro Skid Plate
ODI Rougue Grips
Rear Sport Rack
Pro-Taper Contour ATV mid bend/Trail Tech clamp
grafixghost is offline
post #10 of 21 Old 09-05-2012, 07:54 PM Thread Starter
Quoted: 5 Post(s)
Ohhh yeah I have that in my favorites already and it is a great looking setup by the way! I can't find any black Trail Tech bars on any site right now. I may have to call them or go with the ProTaper or Renthal Twinwall.
2008 Honda Trx700xx
2009 Raptor 90
2005 Polaris 50
Snowdog is offline
