25" tires on the 700xx? - Club700XX - Honda TRX700XX Forum
post #1 of 13 Old 10-11-2012, 10:58 PM Thread Starter
has anyone put 25" radial tires on their 700xx? and will they fit? and how does it ride with the 25" tires?
iceman320 is offline
post #2 of 13 Old 10-12-2012, 12:19 AM
I bought a set awhile ago. Have not mounted them or used them yet, but was told they will fit. And only rub the heal guards when you jump. idk if these are radials for sure?
https://www.club700xx.com/vb/showthre...light=25+klaws
post #3 of 13 Old 10-12-2012, 06:43 AM
xinu's Avatar
I'm kind'a interested in the possibilities as well.
MrQuick what size rims did you get for the 25s"?
I'm thinking that you'd have to go for 12" rims so you can take advantage of range of tire options out there. I'll have to look to see if there are 12" rims out there that have the right bolt pattern and rear wheel offset to maintain the ride width.
xinu is offline
post #4 of 13 Old 10-12-2012, 08:50 AM Thread Starter
Yeah you have to go with 12" wheels and i found some that have the right offset bit i have to change my. bolt pattern to the 4x110 some how. I did find some 23" radial tires but they are 8ply and i think would be to heavy for the xx.
post #5 of 13 Old 10-12-2012, 02:14 PM
The tires I got were 25x12.5x11's so they fit the oem rims.
post #6 of 13 Old 10-12-2012, 06:40 PM Thread Starter
yes but they don't have radial tires for the stock rims in a tread pattern that i like, so that's why i was wanting to go with some 23 or 25" radial tires was to have better tire choices. as far as i know the radial dunlops that come on the 700xx stock are the only radial tires that I have found.
post #7 of 13 Old 10-12-2012, 08:08 PM
hook up with highlifter out of louisianna an you can customize it for your 25 inch wheels
post #8 of 13 Old 10-12-2012, 10:05 PM
JBGILL06's Avatar
I bought some 4/110 wheel adapters so I could run my Rincon's tires when I want to. If I run my Rincon'sw stock tires, which are 25" radial Ohtsu, now Dunlap, I have to take the heel guards off because they balloon at 80mph. But my 25" Bighorns will fit without taking the heel guards off. If anything, the stock heel guards can bend enough to make clearance.
My Stock Rincon tires
26" Mudlite XL's
2008 Honda TRX700XX
*Power Commander V
*Pro Design Air Filter
*Elka Stage One Shocks
*Pro Taper Evo Bars
*Trail Tech Big Bar Clamp
*MSR Clutch Perch
*Powermadd Handguards
*ODI Rogue Grips
*IMS 5gal Tank
*Pro Armor XC Bumper
*PRM Full Skid Plates
*Maxxis Razr II Tires
*ITP Aluminum Rims
2007 Honda Rincon GPScape
JBGILL06 is offline
post #9 of 13 Old 10-13-2012, 12:14 AM Thread Starter
jbgill06 which wheel adapters did you buy? and what offset wheels are you running with the wheel adapters?
post #10 of 13 Old 10-13-2012, 06:32 AM
xinu's Avatar
What were you planning to do for the fronts? Did you find 25x??x10's to fit?
xinu is offline
