Pulls to the left - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 10-25-2012, 04:54 PM Thread Starter
Pulls to the left
My quad pulls to the left real hard? How do i align it to track straight?
Thanks
blackflame is offline
post #2 of 12 Old 10-27-2012, 01:40 PM
4:31 in the Manual, but you can just crank on the tie rod to adjust.
I probably should of asked 1st if you recently hit something?
post #3 of 12 Old 10-27-2012, 03:44 PM Thread Starter
I haven't hit anything, no clue if the person i got it from hit hit anything. Doesn't look like anything is bent. Before i got into it too far just wanted to check here first.
Thanks
post #4 of 12 Old 10-27-2012, 08:55 PM
So you just bought this quad and it pulls to left 1st time you rode it? I'd check everything out real good. And then adjust the tie-rods, you do have the manual right? If not look here....
https://www.club700xx.com/vb/showpost...7&postcount=55
post #5 of 12 Old 10-28-2012, 03:02 AM Thread Starter
Yes just got it,, and yes i have a manual. How do i align the front to the back? I'm also going to check just to make sure the brake is not binding. i will also check to see if it will keeps pulling to the left if i let go of the bars, or if it will go to a point and stop pulling. haven't really rode it too much still riding my street bike.
post #6 of 12 Old 10-28-2012, 11:12 AM
Tire pressure also can make it pull. And checking the brakes is a good idea as well!
post #7 of 12 Old 10-28-2012, 11:31 AM
my 400ex did that after i hit a tree! i bent the tie rod i got the new one honds shop put it on and it still pulled to the left i couldnt never figure it out i sold it like that . the steering stem or a arm may of been bent but visually it didnt look bent though.
post #8 of 12 Old 11-15-2012, 03:50 PM
Snoshoe's Avatar
Does it pull with the handle bar straight? try measuring the tie rods from steering rod end to front tire knuckle, use the outside of the ends. If they are equal it maybe tire pressure. If not the same, you will have to measure the distance between the front tires at the front of the tire then at the rear of the tires toe in should be about 1/4" ( according to Baxter) shorter in the front. after making the adjustment remeasure the tie rods and ensure they are the same length. If this doesnt fix it the steering post, handle bars, or mounts are jimmyjacked. (messed up)
good luck GBA
2008 TRX700xx
13Tfront
Kenda Bear Claws 23x8x11
Custom 2" receiver
rear seat/ strorage box
Ground Hog Disk harrow kit
PEI fog lights
Snoshoe is offline
post #9 of 12 Old 11-15-2012, 03:52 PM
Snoshoe's Avatar
sorry, does it do it under power? rear tire tire pressure or alignment. other wise see prior post
2008 TRX700xx
13Tfront
Custom 2" receiver
PEI fog lights
Snoshoe is offline
post #10 of 12 Old 11-16-2012, 05:08 PM
Snoshoe's Avatar
I hope this shows up. a quick PPT I was thinking of
2008 TRX700xx
13Tfront
Custom 2" receiver
PEI fog lights
Snoshoe is offline
