Hiper tech 3 dual beadlocks - Club700XX - Honda TRX700XX Forum
post #1 of 27 Old 12-17-2012, 09:28 PM Thread Starter
justcustomizations's Avatar
GOT MY HIPERS MOUNTED AND BOLTED UP ON BROS QUAD while my hubs are getting coated red
UPDATE-
Just got my hiper tech 3 rims for front and rear today, ended up being single beadlock rims b/c they dont make dual for 700xx
-Teixeiratech +2 Antivibe Steering Stem
-Precision Racing Shock & Vibe Clamp
-Hiper Tech 3 Red Beadlocks Front + Rear
-ASV Shorty C5 Brake Lever Red
-ASV Standard C5 Pro Clutch Red
-EHS Racing EFI Controller
-Maxxis Razr 2's All the way around
-Honda Racing MX Bumper Red Chrome
-Pro Armor Black Fat Peg Nerf Bars
-K&N Air Filter
-ODI Rogue Grips
-HMF Competition Series Full Exhaust
-Supersprox 13T Sprocket
justcustomizations is offline
post #2 of 27 Old 12-18-2012, 02:38 AM
Should be ok as long as they fit. Do you need spacers for rims for clearance.
I already got my xmas gift lol I decided to get: flexx bars 15 deg quadracer, roxx 2inch anti vibe riser, flex antivibe bar ends, and boyesen flex grips.
When i ride i should feel like im on a cloud LOL.
GLamis XMAS
700xxracer is offline
post #3 of 27 Old 12-18-2012, 11:37 AM Thread Starter
Not sure about the spacers, will look into it....let me know how your handlebar set up feels, I was thinking of getting precision s/v but not sure if it works well
-K&N Air Filter
-ODI Rogue Grips
post #4 of 27 Old 12-18-2012, 06:36 PM
i red up on flexx bars, precision clamp, and soft bars. people complained about precision clamps and how they had problems. Flexx and soft bars were all compliments. the roxx 2 inch riser does the same thing as a aftermarket stem and clamp. $130 vs $300. You need because flexx bars don't have a high enough rise compared to stock bars. 1 inch higher than stock. This setup has to be the best out there.
what i got and prices:
flexx bars 15 deg quadracer $200
roxx anti vibe 2 inch clamp $130
boyesen anti vibe flex grips $50
flex bar anti vibe insert bar ends $50
I don't feel any vibrations or bumps with setup.
post #5 of 27 Old 12-19-2012, 12:21 PM Thread Starter
Is that set up good for mx? I saw how they don't have a high bend on them.
Thanks
-K&N Air Filter
-ODI Rogue Grips
post #6 of 27 Old 12-19-2012, 11:52 PM
The 15 quadracer is the closest to stock in flex bars. soft bars are only 12 degree. Thats why i have the 2 inch riser with them. Makes the hieght id say 1inch taller than stock and with the swivel due to the riser the bars are farther back.
When i talked to fastco about the flex bars on the 700xx. I told them i wanted the most comfortable setup available with close to stock hieght and bend. This is it.
Ill post some pics.
post #7 of 27 Old 12-20-2012, 06:07 PM Thread Starter
Ill post some pics.
Looking forward to seeing them pics
-K&N Air Filter
-ODI Rogue Grips
post #8 of 27 Old 12-27-2012, 12:32 PM Thread Starter
what tire set up would you go with?
-K&N Air Filter
-ODI Rogue Grips
post #9 of 27 Old 12-27-2012, 04:13 PM
Those rims look sweet! Whats a set like that go for? I usually only see the front rims for our quads.
post #10 of 27 Old 12-27-2012, 05:17 PM
your rims are killer they look lighter than omfs, you shouldnt need spacers if the rear is 10x7 4+3 offset for mx the lower the profile the better the 450 pro mx guys run 8 inch rims in back and 10 inch in the front. what size and offset are your hipers?
