Snow riding? - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 12-30-2012, 04:29 AM Thread Starter
Snow riding?
Seeing how all the snow posts are old, i'll start another one What kind of air pressure you running? For snow covered roads and just playing in the in the snow.. I'll have to check but i don't think back rim and tire are stock? The fronts are stock and i do have a new set waiting to be put on, as soon as i get off my lazy ass..
blackflame is offline
post #2 of 8 Old 01-03-2013, 03:21 PM
I don't change anything on mine. You could let some out of the rears if need be, but I run mine between 4-5 all the time.
post #3 of 8 Old 01-03-2013, 04:22 PM
Quoted: 253 Post(s)
I haven't road in the snow yet, except for around the house. A buddy of mine has talked me into going this Sat. My trailer had nearly a foot of snow in it. I'm worried how the 2wd will do on hills with all this snow. I am going to leave my air pressure the same too, I think I'm at 5.5 in the rear's.
post #4 of 8 Old 01-03-2013, 05:21 PM
Dannyboy's Avatar
I went in about 10 inches of snow over new years weekend here in eastern Ohio. It was excellent, the other sport quads (YFZ450 21/20 tires and z400 20/20) were dragging and spinning all day, but my xx sat up so only the front tires were causing any serious drag. I am running 22 maxxis razr 2 front and rear with about 4 psi out back and 6 up front. They ended up voting me trailblazer for the day. Only untouched hills over 50 degrees were sketchy.
Dannyboy is offline
post #5 of 8 Old 01-03-2013, 10:18 PM
going riding friday Low 5 and High 25 for the day. The only thing I change when I ride in the snow is how many layers I put on.
500Rubie is offline
post #6 of 8 Old 01-07-2013, 03:00 PM
hondaman's Avatar
Send a message via MSN to hondaman
Here in Quebec Snow trail the best it's 3 PSI ,, you have better traction !!
TRX 700XX 2008 black and Grey
hondaman is offline
post #7 of 8 Old 01-07-2013, 08:28 PM
quadmonkey700xx's Avatar
In a really wet snow I bolt on the paddle tires, but otherwise I run razers with about 6 lbs in them
quadmonkey700xx is offline
post #8 of 8 Old 01-08-2013, 02:34 PM
I'm riding with 3 lbs in front and 2 lbs in back. I have 22/11R10 Duro for back tire, I really love it !
maxleveille21 is offline
