rim replacement - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 02-05-2013, 07:56 PM Thread Starter
allnew2me's Avatar
rim replacement
Not sure about the sizes rims to buy. I trail ride and I like the clearance on the factory size? Please give me some input I like the RAZR 2 tires or the hole shots. Thanks
allnew2me is offline
post #2 of 11 Old 02-05-2013, 08:36 PM
you only gonna find them tires in 10 inch you wont loss ground clearance if you go with 22-11-10 or 22-10-10 youll have to get some 10x7 4+3 offset in 4/144 bolt pattern
post #3 of 11 Old 02-05-2013, 08:40 PM Thread Starter
allnew2me's Avatar
Can you take the mud crapper nonsense off and fit the beadlock on the Bach side?
post #4 of 11 Old 02-05-2013, 08:46 PM
yeah i believe so you have to take them off for the 10 inch wheel omf has beadlocks and rims that have reinforing rings welded on which is cheaper than beadlocks but all omf stuff is way expensive
post #5 of 11 Old 02-05-2013, 08:50 PM Thread Starter
allnew2me's Avatar
So what size then do you do for the front? Just factory size
post #6 of 11 Old 02-05-2013, 09:00 PM
if you go with a 10 inch rear 4+3 to even it out you will need a 10x5 3+2 offset for front and that will put you 49 -50 inches wide and stock is 46 inches
post #7 of 11 Old 02-05-2013, 09:07 PM Thread Starter
allnew2me's Avatar
How drastic does the steering change? Do you know
post #8 of 11 Old 02-05-2013, 09:10 PM
its better and more stable thats the legal limit in ama pro atv and worcs you cant go no wider than 50 inches
post #9 of 11 Old 02-05-2013, 09:14 PM Thread Starter
allnew2me's Avatar
I think that's what my local trails allow
post #10 of 11 Old 02-05-2013, 09:38 PM Thread Starter
allnew2me's Avatar
I think this is the Max width for our trails
