aftermarket bars? - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 02-15-2013, 11:32 PM Thread Starter
aftermarket bars?
hey guys im wating to go get me some aftermarket handlebars, the stock bars are way to low for me when i stand up so id like to add a few inches in height. The Raptor bend bars seem to be the hoighest i can find at 6.25 inches tall. As anyone tried the raptor bend on there 700xx. If i go that high will i need to get longer cables? Does anyone knoe how high the stock bars are?
Mort75 is offline
post #2 of 7 Old 02-16-2013, 05:27 AM
the raptor bars ought to work but if you go with a riser too you might need longer cables
post #3 of 7 Old 02-16-2013, 11:22 AM
You are not going to gain much height with just bars alone, stock bars are pretty tall already, I bet in the 6" range. I run a 2" taller stem and Pro Taper raptor bend bars, so I am guessing I am about 1.5" higher then stock. (Bars I run have a 5.75" height) I had no problem with that height, but I can't speak for the stock throttle cable, as I use a twist throttle with new cable.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #4 of 7 Old 02-16-2013, 01:40 PM
Dannyboy's Avatar
I have the raptor bend Tusk brand bars and they work great. Had to pop the front brake line out of the one mount and zip tie it up with a little slack is all.
2008 TRX700 - Tusk Aluminum Hand Guards, ODI Rouge Grips, American Star Chromoly Tie Rods, 12T front, ITP 10" Rims with custom 4-leaf clover reinforcement, 22" Razr2's Front and Rear, Moose Fat Peg Nerf bars, GT Thunder Rear re-valve/dual rate setup
Immortal 1995 fourtraxx 300 2WD that has survived everything but armageddon
Husky TE450 street ride - stock with some new plastics
1974 Yamaha DT 125 project
Dannyboy is offline
post #5 of 7 Old 02-16-2013, 06:03 PM Thread Starter
Hey thanks guys. Dannyboy are you using the raptor bends on your stock stem. are you using any typr of riser? If so did get any more heighth then the stock bars
Mort75 is offline
post #6 of 7 Old 02-16-2013, 08:13 PM
Dannyboy's Avatar
Yeah stock riser, didn't notice much if any height gain.
Dannyboy is offline
post #7 of 7 Old 02-16-2013, 08:45 PM
You may want to see if admin still has any of these left. That is if any will fit your needs. https://www.club700xx.com/vb/showthread.php?t=8567
