-   Chassis, Suspension, Braking & Tires (https://www.club700xx.com/vb/9-chassis-suspension-braking-tires/)
-   -   Rox Pivoting risers (https://www.club700xx.com/vb/9-chassis-suspension-braking-tires/8716-rox-pivoting-risers.html)
IIIBuckIII 02-17-2013 09:37 AM
Rox Pivoting risers
whats up guys im wanting to get a few inches of height on my bars if i got the rox risers and put some fatbars on there would i have to change out any of my cables.
tbird88 02-17-2013 12:09 PM
depends on how high you go. the throttle will prolly need to be plus 2 inches.the clutch and front brake have a little more length than throttle, it would be a good time to upgrade to stainless steel cable intead of the oem rubber brake lines:xx:
IIIBuckIII 02-17-2013 06:26 PM
really about 2 or 3inches is all i want to go i plan on getting the rox risers and some renthal fatbars with the trailtech plastic that is 7 bucks i stand and ride alot so id like to have it so im not slouched over so much when riding
Deephaven 04-13-2019 07:24 AM
Contemplating the Roxx myself. I am 6'7" so extra height is needed.
Is there a recommended longer throttle cable? Place to buy the stainless brake line?
Part of me wonders if 2" is enough. I'd hate to extend stuff to have to extend it again. I want to make sure the sit/stand transition is easier as I like to stand often.
Deephaven 04-13-2019 11:37 AM
Also curious if the dummy lights just push out of the plastic dash piece. I am going to Fab something up but don't see how they are mounted
Deephaven 04-13-2019 01:28 PM
Ok, found the manual on here. Answers my second question, figure in case someone searches I'd post the answer.
"Remove the indicator lenses from the indicator sockets by prying them with a small flat-blade screwdriver.
Remove the indicator sockets from the handlebar cover, then remove the handlebar cover from the handlebar."
I was trying to hard...
Footy 04-13-2019 06:56 PM
I use the rox pivoting risers with the stock cables and brake hose but it is maxed out.
I found a mod quad dash plate on ebay for about $23 and it is great. If you need pics I can get them.
Deephaven 04-14-2019 07:49 AM
Picture would be great. If it is easier to text, my cell is in your pm.
Footy 04-17-2019 05:49 AM
Photos sent to your cell.
Deephaven 04-17-2019 06:47 AM
Thanks. That thing is sweet. I designed something similar to hide the lower mount, but for $20 that is a no brainer. Off to ebay!
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
