700xx Suspension for 450r IRS kit? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 03-28-2013, 07:14 PM Thread Starter
Okay, so several years back, I think in 2006, Sonic Offroad came out with the Spyder Kit for sport quads. Some pics should be attached. It was basically an IRS setup that you could bolt right onto sport quads. Long story short, something reminded me of them and I cant find any info on the kits anymore. From what I remember the kits were $3500, so eff that anyway, I want to make my own kit!
Does anyone know if someone has attempted to build and IRS kit for a 450r from 700xx components? If so please send me any info you have! Thanks much.
I can do all the fabrication of the frame myself, but to keep costs down I need to find something for the rear a-arms, drive shafts, carrier, hubs, spindles, etc.
If anyone has any of the parts listed above sitting around and is willing to donate to the cause, please let me know. If anyone has any of the parts listed above and would like payment, please think about donating HAHA. Just kidding, please let me know what you got.
TeamExileRacing is offline
post #2 of 6 Old 03-28-2013, 07:25 PM Thread Starter
from the looks of it, the 700xx carrier will be too skinny to adapt it to the 450r, there is no way I would be able to get the carrier centered on the bike and have the chain strait. I may have to use an outlaw carrier Regardless, let me know if anyone has heard anything about someone doing this before.
post #3 of 6 Old 03-28-2013, 08:52 PM
easystreet's Avatar
There was a guy on raptorforum.com that put a Polaris Outlaw IRS on his Raptor 700. He stated that it was fairly easy to do and had pics of it. It turned out quite nice from what I remember.
'08 710XX
+3mm HotRods stroker crank
Port & Polish (myself)
HotCam 3
Velocity intake
PCV (dyno tuned)
easystreet is offline
post #4 of 6 Old 03-28-2013, 09:00 PM
easystreet's Avatar
Why do you want to put it on a 450R? Most often people want the 450R for track riding which should stay solid rear. Trying to morph a Raptor with it seems very obvious.
The xx motor would need to be fabricated into the 450r frame somehow to make it a usable system. Or you would have to create your own slave gear jack shaft system to use a standard motor.
'08 710XX
HotCam 3
Velocity intake
PCV (dyno tuned)
post #5 of 6 Old 03-28-2013, 09:12 PM
youd be better off transforming a 680 rincon or grizzly 700 into a sport quad then trying to do what you want to do . thats just my opinion!! good luck if you will wait there will be an oem one in a couple of years! that member from germany or somewhere over there has already done that!
post #6 of 6 Old 04-02-2013, 06:08 PM
Sounds like a great project , I tried to get a hold of a Sonic IRS and email them constantly , I got no replies.
I thought about using XX bits but the problem is weight. The XX axle alone weighs 26 lbs , add 4 a arms , 2 shocks and a subframe to take the strain. Makes no sense at all.
Being a Honda fan , using Polaris 525 IRS is not an option for me but that would make you're life easier and alot cheaper $ wise and more availible. XX parts are at a premium , due to the model being dropped after 2 years and it being a Honda Baja winner.
I will offer one bit of advice , use a 04/05 TRX450R motor and fit a swaybar. IRS and a stock 06+ motor .
