what tires for sand? - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 03-29-2013, 12:24 AM Thread Starter
so I have been thinking about buying a set of tires for sand that I could mount on the stock 700xx wheels. so which tires are some of you guys mounting on the stock wheels to run in the sand?
iceman320 is offline
post #2 of 10 Old 03-29-2013, 07:25 AM
Jay-Le~no's Avatar
It is hard to find an 11in. sand tire, I went to 10in. rims to get a better variety of sand tire options and use my stocks for dirt so I don't have to change my tires. Another option that I recently encountered is that you can ship Skat Trak old tires and they will make paddles out of them for you and skat traks last longer because they are a molded paddle. I have 20in. Skat Traks and 22in. Sand stars, skat traks are worth the extra $...
Jay-Le~no is offline
post #3 of 10 Old 03-29-2013, 08:48 AM
I don't know for a stock rim but skat trak is the way to go!
post #4 of 10 Old 03-29-2013, 04:41 PM
As far as I know, no one makes a sand tire for an 11" wheel. I bought a set of 12" Sand Stars mounted on ITP 12" C5 wheels.
post #5 of 10 Old 03-30-2013, 12:50 AM Thread Starter
where did you get the sand stars mounted on the c5 wheels from roadkill?
post #6 of 10 Old 03-30-2013, 01:59 PM
Got the pair from RemingtonSteel (used)... ITP no longer lists the C5 wheel on their site though. Sand Stars are 22x12. If I had to do this over, I'd probably get a pair of 10" wheels and sand tires... with the correct offset. Myself, I prefer to have my sand tires on their own wheels so that I only have to switch wheels and go... rather than mounting sand tires to one shared set of wheels and then having to re-mount my trail tires back up later.
post #7 of 10 Old 03-30-2013, 11:08 PM Thread Starter
yeah me too that's why I was hoping that somebody would make some tires for the sand that would fit on the stock 11" wheels. cause I already have two sets of wheels and don't really need a third set sitting around.
post #8 of 10 Old 03-31-2013, 10:57 AM
easystreet's Avatar
"skat traks last longer because they are a molded paddle"
Incorrect statement. Skats are not molded and they are more likely to lose a paddle compared to a molded tire such as Sand Stars. Therefore, may not last as long.
Skat traks are a better tire for hooking up though. Be aware that a good sand tire requires more power due to them hooking up so much better.
'08 710XX
+3mm HotRods stroker crank
Port & Polish (myself)
HotCam 3
Velocity intake
PCV (dyno tuned)
easystreet is offline
post #9 of 10 Old 04-03-2013, 11:05 PM Thread Starter
yeah I realize that they will require more power. I just wish that I could find some sand tires that would fit on the stock rear 11" rims of the xx?
post #10 of 10 Old 06-02-2013, 09:28 AM
Jah_82's Avatar
I modified my old LTR450 DWT 10inch wheels and use them with hauler paddles and they work great. I am thinking of going 8 or 9 inch with modified 450r hubs with "x" pattern mx type tires like holeshot or razrs. Look at the vid below, these guys are having a lot of fun with "x" pattern tires out there, I think you can really let loose with those type of tires and have some fun.
-Oregon-
2008 Honda TRX 700xx
13T Front Sprocket (going back to 14t for sand)
Airbox lid delete
Spark arrester delete
10' rear DWT blue label with paddle for sand
Jah_82 is offline
